modem7
10k Member
Yes. In post #17, I believe that robbo007 wants to see a photo of just how exactly the OP implemented that (post #1).Wouldn't it be easier just to ground the POWER GOOD pin coming off the power supply?
I will see if I have pictures of how I made it. But I only added the two wires on the P8 power connector which goes to the motherboard. The pins are GND and PG as shown in the picture.
What voltage reading do you get on the PG line when you press and continue to hold in the button ?When i put those 2 wires on P8 connector side by side with the normal, i get nothing when i press the button, with multimeter i see voltage drop to around 2.2v from 5 but 5160 continues to run normal![]()
I asked because if you had just quickly pressed-and-released the switch, your multimeter may not have shown you the lowest voltage value reached (unless your multimeter has min/max functionality, and even that has limitations).hehe as i wrote: with multimeter i see voltage drop to around 2.2v from 5v but 5160 continues to run normal![]()
Yes.could be i should try other resistor ? ...
In post #1 is "100R". That is 100 ohms.... think i choose a 100k resistor as the initial poster had.
I think that card is also part of the Professional Debug Facility. It may have shipped in multiple packages.
/N
Permits use of non-maskable interrupts on non-IBM
computers . To use non-maskable interrupts, you must
have a system that is equipped with the proper hard-
ware, such as the following products:
* IBM Professional Debugging Facility
* Software Probe (Atron Corporation)
The symdeb utility requires only the hardware pro-
vided with these products ; no additional software is
needed . If you are using one of these products with a
non-IBM system, you must use the /n option to take
advantage of the break capability . Using a non-
maskable-interrupt break system is more reliable
than using the interactive break key because you can
always stop program execution regardless of the state of
interrupts and other conditions.
Sure--I still have the NMI ISA card that IBM packed with the "Options and Adapters" books.
