Hmmmm.....
Good news but not really. My second board (the one that was in storage) is now working but I have no idea why.
As I mentioned before I gave the second board a run with the PETTESTER. It didn't fire at all. However, while it was in there I did some basic checks on the CPU with my voltmeter. Address lines seemed ok (neither very high or very low), a clock seem to be there (or rather 2V was there) and RESET was at about 4.5V. On pin 7, sometimes it was 0.01 but other times it was anything between 1.0 and 0.01?
Anyway, I thought I'd drop the BASIC 4 ROMS in just to see what happened on the CPU Pin 7. Switched on and VOLIA, a BASIC 4 prompt??
It wasn't prefect. There was the odd character at odd places on the screen but this was the state it was in when Philip Avery and I stopped working on it. At the time Philip felt the trash was probably due to a failing 2114. He'd already changed and socketed one. I clipped the second 2114 off and piggybacked a good one over the pins. The screen is now perfect, so it seems that was the problem. I'm now going to add a socket and the replacement.
I'm not estatic though because I have no idea why the machine has suddenly started to work. I means it can fail again just as easily. Well, at least while it's going I have a good board I can make comparisons with. It might help me fix the faulty one, if it lasts.
Perhaps it is dodgy sockets in this board (in particular a dodgy U9 socket, as the PETTESTER didn't work when there). I didn't check the socket continuity in this board like the other one. If it fails again that's the first place I'll look.
Tez
