djfitzgerald
I'm working on modifying a PC/AT to use a CF card as a removable solid state hard drive using an XT-IDE card. I want the card to be removable, so that I can easily muck about with the hard drive on a modern computer. While the easiest way to do this would be to use an IDE-to-CF adapter with a bracket plate (such as this: https://tinyurl.com/y6p3gmuu), this will cost me an expansion card bay.
Does anybody here have any recommendations or ideas for adding the card slot in a way that doesn't obscure an expansion card bay?
One idea that I had was to remove the small panel that sits between the battery and the power supply, and create a custom bracket plate for the CF card (probably by mangling a IDE-to-CF adapter bracket plate). However, I worry that its close proximity to the power supply heat vent could cause a problem. Does anybody have any experience with this, or any other ideas? (Also: what the heck _is_ that panel for, anyway?)
