Marty
Hi All;
K1Atn, for now assuming that You do indeed have the Eprom disabled, then having the Eprom in or out would make No difference..
So I would concentrate on looking at the Signals, on the Z-80 and on the Buss that have to do with Reading and Writing to the Memory.. Start from the the Memory Board and Look at the RD and WR signals tracing them back to the Z-80.. If they look the same, then You have a problem..
Also, check to see that You Aren't fighting Yourself, that the MWRT coming off of the Z80 Board is turned off or dis-connect from the Buss, since You are using You Front Panel for these signals and Not the Z-80, since at this point You are not using the Eprom for a Software Monitor to replace the lights and switches of the Front Panel..
Let us know what You find..
THANK YOU Marty
THANK YOU Marty
