Altos ACS 8000 7s Z80A
ribbets
Palmyra, Maine
It's dusty and there is a couple of screws missing out of the cover
I finished opening it up ..I thought they had two floopy but this one, only had one. WHAT do I need for a monitor and keyboard?? and the 7S in the serial number does not match up with any I've looked up online
Erik
Site Administrator
Staff member
San Jose, CA
I'm not quite sure what the 7s means, but the system will hook up to just about any dumb terminal and/or a PC running a terminal program.
It may be a hard drive model if it only has the one floppy drive.
ribbets
Palmyra, Maine
Totally Fitting
Totally Fitting
Eriks web site was the one that got me to The Vintage Forum and also was my 100 posting to senior member:p
ahm
Moderator
Staff member
New Jersey
I imagine you can connect a serial terminal (or equivalent) to one of the serial ports on the back of the unit.
One of them is probably the console.
EDIT: console settings are likely to be 9600 8n1
Terry Yager
Saginaw, MI, USA 48601
Mine is kinda buried at the moment and I don't recall the exact model number, but it does have the hard drive installed (hidden under the mainboard). I'll know more about it soon (I hope), now that I have a bootdisk (TNX, Erik!).
--T
Sharkonwheels
South Florida
Yo, Terry, guy i used to work for, has offered me an Altos 586 for free. He has had it since new!!
Take it?
What the heck is it?
Tony
Terry Yager
Take it?
Tony
It's an 8086-based multi-user system, running Xenix or possibly a multi-user version of CP/M. It should be interesting to collect & play with. I used to have a 686, which is a 286 version. It ran Xenix until I accidently installed Concurrent CP/M/DOS on it one day. I can probably get mine back...mebbe I will...
--T
Sharkonwheels
South Florida
Just powered up that ACS 8000-2A.
SOUNDS like it has a hard disk...
2 x 8" floppy drives. I swear I saw the lights dim... :D
Yo! Erik! Got some more bootdisks? :cool:
Tony
ribbets
Palmyra, Maine
This one looks like a winter project.. Needs a cleaning and the floppy has that white buildup on the outside metal, that may need the dremmel wire brush and my new vacuum with the grounded head..
