Trixter
Oh, don't think I'm not above paying for the service, including shipping both ways. Get your wish list updated ;-)
Buy a kit, will probably have 3 sizes minimum, one of them will fit. I've never had to specifically hunt out a certain size.Does anyone know the best size of torx security bits to use with the 5150 and 5160 power supplies?
May I borrow your thread for a question which is not entirely off topic. I should replace the mains cable receptacle in my XT but I understand that there could be high voltages lurking inside the PSU even when unplugged. At least there are some warning stickers suggesting so. My question is, What Should Every Man Know Before Opening a PSU, just not to do any harm to himself and the hardware?
Those caps look like plain old film capacitors--they rarely go bad. If you do replace them, be sure to check for an "X", "X1" or "X2" mark on them and replace them with similar types--those are "safety" caps, made to fail in a defined way.
What does the relay do on this PSU?
Right across the AC line? So its funciton is EMI suppression. So it's either shorted or open. If it's shorted, magic smoke. If it's open, the PSU should work anyway.
