Hi all,
I'm not exactly an Apple expert, but I surely have a long enough record of repairs (starting in the middle 1980s).
Now, the Apple //e wikipedia page:
https://en.wikipedia.org/wiki/Apple_IIe
currently states:
"The IIe also switched to using newer single-voltage 4164 DRAM chips instead of the unreliable triple-voltage 4116 DRAM in the II/II+"
I think the switch was purely dictated by the chip "density" of 64kbit VS 16kbit and not even the triple supply VS single supply issue, since the Apple //e also had the same PSU as the previous models. I'm quite sure the 4116 isn't unreliable per se, the power supply must be indeed more reliable if one has 4116 DRAMs, but that's another issue entirely.
Facts: I repaired several (> 10 so far) computers that use 4116 (PET 2001N, PET universal boards, ZX spectrum, Apple ][, arcade PCBs etc...) and the current total number of failed 4116 I have found is 3 and this is an unfair number too:
One 4116 was split in half from the beginning, probably because of bad handling during shipping.
One 4116 failed on the same data line of an already failed 4116, that might be because of the already failed chip driving the data line when not selected.
So, in my experience, 4116 are indeed at least as reliable as the much denser 4164 (that I substituted far often, but on a larger sample of repairs too).
What do others think?
Frank IZ8DWF
currently states:
Frank IZ8DWF
