vanderk
I have been working on two Astec Kaypro power supplies (AA12450 and AA12350) on and off for the better part of a year or so. I simply cannot get them working! Both units have been totally recapped, resistors checked, and I even replaced all the transistors to include the power transistor. Also replaced were all the diodes and bridge rectifier. I have replaced almost everything except for chokes. All resistors were good and I see no shorts on the common mode, control and power transformer (T1, T2, and T3).
Here is the issue with both units (they both exhibit the same problem):
- While slowly increasing voltage on a variac, the crowbar engages at around 40-50VAC. I do have B+. There is a high pitch chirp coming from the capacitors, and I can also hear the crowbar clicking.
- I see -12vdc when the crow bar engages and, as intended, no output on the 5VDC and 12VDC points.
- Lowering the variac voltage to just before the crowbar kicks in, I see approximately -12VDC, 6VDC, and 14VDC.
I am completely stumped and refuse to give up on this! I was careful when replacing components and used only exact replacements and close values.
Any assistance would be greatly appreciated!
Thank you,
Chris
Thank you,
Chris
