Power supply does not work when connected, function of the fuse
The power supply has only one connector, and that is the 50-pin in the picture in my last post. It connects to the system board, and the drives, fan, and system board receive power from this 50-pin connector. It would be nearly impossible to test the power supply if it were connected to the system board.
The power supply still does not work when connected to the system board. I tried without the drives connected, but it still does not work. It only seems to work when it's not connected to the system board.
I can only conclude something on the system board is telling the power supply not to power on. I didn't see anything unusual about the system board except I had never seen a fuse on one before (picture attached). What does this fuse do? This is the only thing I see that I can easily replace.
