Wreck
Hello,
My trustworthy 3032 developed several hiccups over the past months. Suddenly it wouldn't start, only with the help of the PET ROM/RAM board it would, but the Commodore text would be "wobbly" (with interference).
The system has the original white sockets installed. Applying a bit of pressure on UF10 the text would go from wobble to normal. After releasing pressure, the wobble would come back.
I concluded that the culprit was the sockets; I de-soldered the old ones and soldered new, good-quality sockets back in (UF10, UD9-UD2, UC7-UC4).
After putting everything back and powering on, nothing happened (except a nice and steady picture, but not the standard "garbage screen"). Even with the help of the PET ROM/RAM board, no change in behavior.
I measured VR3 and VR4; both output at 5.00V. VR5 is slightly less at 11.72V, don't know if this could be a problem.
PIN40 of the 6502 was found LO instead of HI; turned the machine OFF and measured R15,R16, C66-C68 and found all OK, so turned machine back ON and suddenly everything worked as it should. During loading a program from tape, the system froze; PIN40 was LO again.
I tested pins 1-8 on the 555 and got the following (with a logic probe)
A2 555
PIN1 LO
PIN2 LO
PIN3 HI
PIN4 HI
PIN5 NIL
PIN6 HI
PIN7 HI
PIN8 HI
A3 74LS04
PIN1 LO
PIN2 LO
A10 7417
PIN13 LO
PIN12 LO
I think further troubleshooting is needed; I believe the problem is somewhere in the timing logic(?).
Any ideas appreciated, thanks
Joe
A2 555
PIN1 LO
PIN2 LO
PIN3 HI
PIN4 HI
PIN5 NIL
PIN6 HI
PIN7 HI
PIN8 HI
A3 74LS04
PIN1 LO
PIN2 LO
A10 7417
PIN13 LO
PIN12 LO
Joe
