QuantumII
No, I still don't get it to work. Will do a few experiments today and I'll let you know the results.
SMC_WD 0x60
w00t!!! IT WORKS!!! Yay!
When I trsted it with the above setup program and Pacet driver, the Twisted pair unshielded part connector of the card worked like a charm!
Wait a minute, it works in my 486, but parts of it seems to halt my XT. I guess it is because I'm running the packet-driver from a floppy disk, and not a faster hard drive.
It seems like most programs taking controll of expansion cards seems to fail when run from a floppy disk, or do they just use 286 codes?
after an awfull lot of trial-and-failing, I'm rather confused. The older crynwr driver from the crynwr site tells me that the memory at the memory adress are not used by the WD board, a statement that's not true.
I'm more confused because I got it working ONE time, however I haven't been able to do so later on.
I'm confused, and I would be VERY happy if ANYBODY made ANY comment with troubleshooting or their explanation on getting this card to work in an XT.
Well, I've just received this card, and after messing arround a while, I managed to put it to work doing several things.
First, I used the jumper on the top, labeled W1, closing it to reset the internal EEPROM on the card, then after turning the PC on and off so the card erases the EEPROM, I opened the jumper and ran the setup utility from WDPLUS.ZIP, configuring it on 280h, IRQ 3 and ADDR D000h. Then, ran the packet driver, SMC_WD.COM, this way:
smc_wd 0x60 -o 3 0x280 0xD000
And it's done, the driver loads, and after defining the ip, netmask, gateway, and dns (set ip=xxx...., etc) the card works perfect, I managed to connect to irc, use ftp, etc.
Holy crap.. have I really stared at this and said "maybe later" for a two and a half years now? Unbelievably this auction and item is still available. Now.. to think about it some more. ;-)
Pc xt, 8088, 640k ram, cga.
PC XT, 8088, 640k RAM, CGA
