Desperado
- Joined
- Nov 25, 2017
- Messages
- 6,827
Yes, same signal!Now can you check G5 pin 14 using your oscilloscope with the same configuration - and check that the signal is the same as found at G1 pin 6.
Thanks sir!G5 is probably toast.
Warm up the soldering iron...
4,5 VCan you just check pin 11 (using your oscilloscope) as Hugo has asked to see what the actual DC voltage level is please.
Ok, thanks sir!G5 is dead!
No this machine haven't the 6545 ic...I assume this machine has a CRTC chip?
I have signals but not waveform unfortunately...Ok, so can you check the HDRIVE, VDRIVE and VIDEO signals on J7.
See if all of them are missing or not.
