dave_m
Sorry I didn't see the bit about Repeat and M... it went up to 0.4v this time when I held them down!
OK! We have a good video signal into the video board. The problem may be in the video board (ouch).
Ouch as in.. ouch that's kaput, or as in, "you've a lot of soldering to do!"?
This one here says it has the pulse tester.. I can pick this up tomorrow:
http://www.maplin.co.uk/logic-probe-5671
Yup; unless you're lucky it'll be tough to troubleshoot without a 'scope....MikeS, what do you think?
-Dave
Removing the character generator chip (UA3) will result in a screen of reverse spaces; on mine that gives about 2.5V on pin 7.
D'oh! J7-1, not J1-7; correction made, thanks....I also get 2.5V on J7-pin1 (the video signal).
Did we ever get the voltage readings on the 3 pins of the display's voltage regulator?
int 21h,Tested the transformer directly... assuming it is still AC, the two cables going from the transformer are now only reading 0.1v (its set at 200 so I am only guessing that it's 0.1 and not say, 10v)
That looks pretty cool!
I can't borrow one, I don't know a single person with any electronics equipment..
I could pick this up tomorrow if I win it though - will this do the job do you guys know? It's definetly looking tricky but there's no harm in learning about them either! Nice article on your site there - I'v basically very little knowledge of the terminology used here (so I had no idea what a HO was until I saw it in your article) which doesn't help either!
http://www.ebay.co.uk/itm/TEKTRONIX..._Measurement_Equipment_ET&hash=item3ccdb26b88
Especially after that 'spark'... ;-)int 21h,
You may be a little over your head in this type of electronics repair since it involves secondary AC and transistor analog circuits and I worry because of the thousands of volts generated on the video board for the CRT.
-Dave
No, just that some things you say are a little contradictory and misleading; you would have had to touch something else to get a spark (unless your meter was set to amps, in which case it probably has a blown fuse)....The sparks don't scare me if that's what you're thinking
We don't want you to either, which is why we're thinking that maybe you shouldn't be poking around making sparks inside the display ;-)I just don't want to blow anything..
