billdeg
Technician
FWIW, if you use that image file I gave you the link to you just restore the image to a disk and you're done.
Not that simple if you are trying to make a 360 disk and you're using a 1.2M disk drive. There is ample documentation and commentary on the web about the related issues, won't repeat them here. Best that a 360 disk drive is used to make 360 disks.
