mateuszviste
Today I published a new DOS tool: a "virtual floppy over Ethernet", targeted to ancient PCs.
ethflop is a DOS TSR that emulates a floppy disk drive. The emulated (virtual) floppy disk is, in fact, stored on a Linux server as a floppy image. All the communication between ethflop (the TSR) and ethflopd (the Linux daemon) is exchanged over raw Ethernet.
homepage: http://ethflop.sourceforge.net/
ethflop can be used as a mean to copy data from one PC to another (instead of using physical diskettes, you use virtual network floppies - faster, easier and more reliable). It can also be used as an easy mean to create backup images of existing floppies, using diskcopy. And of course, it can also simply act as a permanent storage for a retro computer - the biggest floppy disk ethflop is capable of emulating is 31M big.
It works on 8086-class machines, and the TSR's resident size is under 2 KiB.
