got the colt. looks like Ive hit the same roadblock everyone else has. would love to get a 720kb floppy drive running but I cant seem to. I don't even mind if its set as the B drive. I replaced the floppy cable with one with a twist but still nothing. drive A will work but when I attempt to access drive B if fails, if I try again it makes drive A drive B and accesses it....bizarre.
I tried that too, couldn't make it work.
The controller is actually based on the Amiga. Commodore used to sell drive kits for 3.5" drives, so it should be possible to make it work with the right drive.
The kits are:
PC 910 Single 3.5" 360K/720K, Internal for PC10/20-I-II-III.
PC 915 Single 3.5" 1.44M, internal for PC10/20-I,II,III, PC30-III EC
PC 920 Single 5.25" 360K/1.2M, Internal for PC10/20-I-II-III.
But I've tried various 3.5" drives I had lying around, including some Amiga ones, and I could get none of them working. It seems it does not use standard signaling for the motor, so the drives did not spin up when a read command was sent. The led came on, but nothing happened.
I've heard from people here (I think it was SkydivinGirl) that a Gotek virtual drive works.
Oh by the way, the mouse port is also Amiga-based. I have some Amigas myself, and I actually used an Amiga mouse (model 1352, don't confuse it with the 1351, which looks the same and has the same 9-pin joystick connector, but is meant for C64 and Geos) successfully on my PC10-III in the past. It came with a standard Microsoft mouse driver, so it was fully compatible.
Oh, and why all this talk of PC10-III/PC20-III?
As you might know, the Colt is a rebranded PC10-III, so same motherboard.
The PC20-III is also the same machine (the motherboard in mine actually says PC10-III), but came with a 20 MB HDD as standard (a WD XT-IDE drive).
I have successfully installed a 40 MB ST351A/X in my PC10-III back in the day.
