I HAVE PROGRESS. The images are loaded on the drive, and with the proper jumpers, I can do a BOOT DU0 (I pulled the RD52 out, so the first device appears to be the "floppy").
When I do it though, with any of the bootable images (XXDP or RT11), it reads for 6 tracks,., then stops. The screen says something like "Starting system from DU0..." but never says anything else. I've tried the DISK0029 (which is supposed to be a bootable XXDP), and DISK0001 (which should be the first boot disk of RT11). Both do the same thing.
So this sort of implies my RQDX3 is probably okay (in fact at one point I pulled the controller and powered up, forgertting I had pulled it, and got a NO CONTROLLER FOUND, so i guess that's good), and the drive is probably configured right. I'm SLIGHTLY concerned that the memory size is showing 4088 K Bytes - is that the right amount for a 256k memory board?
I did let the TEST in the console run for a half dozen passes, no errors.
I know the floppy boot is supposed to be slow, but this appears to be locking up on boot
I'm going to let it sit for now to see if it's waiting to timeout on something. Hitting <enter> doesn't get anything from the console, so it appears to be halted
. I can do a reset on the front panel and get the monitor back, or do a reboot, but seems to be wedged.
I think I'm doing everything right. I have YET ANOTHER KDJ11B board to try, but I'm saving that for a last resort. Am I doing something wrong?
View attachment 1255442View attachment 1255443
