shevett
That would be meThe OP.
| VCF Montreal | Jan 24 - 25, 2026, | RMC Saint Jean, Montreal, Canada |
| VCF SoCal | Feb 14 - 15, 2026, | Hotel Fera, Orange CA |
| VCF East | Apr 17 - 19, 2026, | InfoAge, Wall, NJ |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF Southeast | June, 2026, | Atlanta, GA |
| VCF Midwest | Sep, 2026, | Schaumburg Convention Center, IL |
I.n.s.t.a.l.l.a.t.i.o.n. E.r.r.o.r.
Error : Installation diskette contains invalid volume ID.
If you cannot immediately identify and correct the error,
please call the HOTLINE number on your instruction sheet
for assistance.
@ <EOF>
Device Unit
name numbers Source Device type
DU 0-255 CPU ROM RD51, RD52, RX50, RC25, RA80, RA81, RA60
DL 0-3 CPU ROM RL01, RL02
DX 0-1 CPU ROM RX01
DY 0-1 CPU ROM RX02
DD 0-1 CPU ROM TU58
DK 0-7 CPU ROM RK05
MU 0-255 CPU ROM TK50, TU81
MS 0-3 CPU ROM TK25, TS05
XH 0-1 CPU ROM DECNET DEQNA
NU 0-15 CPU ROM DECNET DUV11
NE 0-15 CPU ROM DECNET DLV11-E
NF 0-15 CPU ROM DECNET DLV11-F
Commands are Help, Boot, List, Setup, Map and Test.
Type a command then press the RETURN key:
List/change the switch boot selections in the Setup table
Switches 2,3,4 on on off = A
Switches 2,3,4 on off on = DL0
Switches 2,3,4 on off off = MS0
Switches 2,3,4 off on on = MU0
Switches 2,3,4 off on off = E
Switches 2,3,4 off off on = blank
List/change parameters in the Setup table
A - Enable Halt on break 0=No, 1=Yes = 0
B - Disable User friendly format 0=No, 1=Yes = 1
C - ANSI Video terminal (1) 0=No, 1=Yes = 1
D - Power up 0=Dialog, (1)=Automatic, 2=ODT, 3=24 = 1
E - Restart 0=Dialog, (1)=Automatic, 2=ODT, 3=24 = 1
F - Ignore battery 0=No, 1=Yes = 0
G - PMG 0-(7) 1=.4us, 2=.8, 3=1.6, 4=3.2,...7=25.6 = 7
H - Disable clock CSR 0=No, 1=Yes = 0
I - Force clock interrupts 0=No, 1=Yes = 1
J - Clock 0=Power supply, 1=50Hz, 2=60Hz, 3=800Hz = 0
K - Enable ECC test (1) 0=No, 1=Yes = 0
L - Disable long memory test 0=No, 1=Yes = 0
M - Disable ROM 0=No, 1=Dis 165, 2=Dis 173, 3=Both = 0
N - Enable trap on Halt 0=No, 1=Yes = 0
O - Allow alternate boot block 0=No, 1=Yes = 0
P - Disable Setup mode 0=No, 1=Yes = 0
Q - Disable all testing 0=No, 1=Yes = 0
If you jumper your TEAC floppy correctly, it will be a true RX33 workalike and thus be able to read and write RX50 floppies.Teac drives emulate an RX33, not an RX50
shevett@surfboard:~/src/tu58fs/bin-ubuntu-x64$ ./tu58fs -xxdp --unpack ~/tmp/DISK0029.img ./disk29.dir RX50
Error while parsing commandline option:
No <devicetype>
Syntax: -up | --unpack <filename> <dirname> <devicetype>
Read a binary disk/tape image, and extract files into directory
Read files from a directory and pack into binary disk/tape image
<device_type> can specify a different device geometry for the image,
allowed: TU58,RP0456,RK035,RL01,RL02,RK067,RM03,RS034,TU56,RX01,RX02
shevett@surfboard:~/src/tu58fs/bin-ubuntu-x64$ ./tu58fs --port /dev/ttyUSB0 -b 38400 -d 0 c 11XXDP.DSK
[18:30:12 info] Unit 0: zero'd new tape on '11XXDP.DSK'
[18:30:12 info] Unit 0 read/write fmt=none size=256KB=512 blocks, img file="11XXDP.DSK"
[18:30:12 info] Using serial port /dev/ttyUSB0 at 38400 baud with 8N1 format.
[18:30:12 info] TU58 emulation start
[18:30:12 info] R restart, S toggle send init, V toggle verbose, D toggle debug, Q quit
[18:30:12 info] emulator started
[18:30:20 info] verbosity set to ON; debug OFF
Trying DD0
Message 14
Non existent controller, address 17776500
Wait - if it's a proper 11/73, then it has a n H9278 backplane. The first three slots of this are Q22/CD. Only from slot 4 on is it Q/Q. So you've got the DLV11J in the wrong place - put it in A-B of slot 4, leaving slot 3 C-D empty.The only other thing I can think of us bus ordering. My understanding is that Qbus uses a 'serpentine' layout. Looking from the top of the cage, CPU goes in the top slot, sockets A-B-C-D. Next board in slot 2 is memory (also all positions). Then I have my RQDX3 in positions A-B, and I put the DLV11J in positions C-D, right next to it. That should be fine, right?
... you wouldn't happen to have images in TU58 format would you? I'm trying to use the TU58fs toolkit from https://github.com/j-hoppe/tu58fs but I'm getting things like the images are in the wrong format...
Okay, that solved one problem. The bootstrap sees the DLV11J, and if I do a BOOT DD0 it no longer says controller error.Wait - if it's a proper 11/73, then it has a n H9278 backplane. The first three slots of this are Q22/CD. Only from slot 4 on is it Q/Q. So you've got the DLV11J in the wrong place - put it in A-B of slot 4, leaving slot 3 C-D empty.
$ ./tu58fs --port /dev/ttyUSB0 -b 600 -xxdp -d 0 r 11XXDP.DSK
[23:58:49 info] Unit 0 readonly fmt=XXDP size=256KB=512 blocks, img file="11XXDP.DSK"
[23:58:49 info] Using serial port /dev/ttyUSB0 at 600 baud with 8N1 format.
[23:58:49 info] TU58 emulation start
[23:58:49 info] R restart, S toggle send init, V toggle verbose, D toggle debug, Q quit
[23:58:49 info] emulator started
[23:58:51 info] verbosity set to ON; debug OFF
[23:58:52 info] verbosity set to ON; debug ON
....[23:58:52 info] unit 0 sync
..............................[23:58:55 info] unit 0 sync
..............................[23:58:58 info] unit 0 sync
........[23:58:59 info] flag=0x00 last=0x00
[23:58:59 info] <NULL> seen
[23:58:59 info] flag=0x04 last=0x00
[23:58:59 info] <INIT> seen
[23:58:59 info] flag=0x04 last=0x04
[23:58:59 info] <INIT><INIT> seen, sending <CONT>
[23:58:59 info] flag=0x00 last=0xFF
[23:58:59 info] flag=0x08 last=0x04
[23:58:59 info] <BOOT> seen
[23:58:59 info] boot unit=0 blk=0x0000 cnt=0x0200
[23:58:59 ERROR] boot serial write error unit 0, expected 512, received 64
[23:59:02 info] unit 0 sync
[23:59:05 info] unit 0 sync
[23:59:08 info] unit 0 sync
[23:59:11 info] unit 0 sync
[23:59:14 info] unit 0 sync
[23:59:17 info] TU58 emulation end
600 baud? Really? Or did you mean to use 9600 baud?
Hi, what did you do exactly to boot from the gotek device?It seems that I managed to get Gotek to work with RQDX3. Some experiments more.
"interface = ibmpc" !!!But, I'm not able to boot "No Disk present or drive is not loaded".
./tu58fs -p /dev/ttyUSB1 -b 38400 -f 8O1 -xxdp -d 0 r ./11XXDP.DSK
