VERAULT
So I have been on an 8bit kick for years now. I feel like we are so far removed from 8 bit computers they just seem more interesting to me now more than ever. I have plenty of IBM PC's but I still remember using them so I guess I just havent done much with them Sans a few Early IBM 5150s etc repairs.
Well time to get these off the shelf and change all that. This is a continuation from this thread: https://forum.vcfed.org/index.php?t...l-find-a-baby-at-computer-case.1245773/page-3
I pulled a battery damaged early 486 full tower system out of my crawlspace and began to take it apart and see if I cant bring it back. Thanks to @seaken I got a New case for it.
A little backstory to where we are now. I pulled the battery and did a few repairs on the corrosion as well as a new coincell battery holder. I upgraded the cpu from a 486DX 33mhz to a 486DX2 66mhz and added a flat broad heatsink.
As you can see the unit only has 30 pin simms. I am down to my last 6 modules with only one 4mb 30 pin simm. Do you think this unit can take 4mb 30pin simms? As is 8MB of ram is not going to cut it for me. I know I have seen brand new 30 pin simms (I think mainly for older macintosh computers but I may be wrong). What do you guys think is there new ram and can I use 4mb modules in here? 12mb is really the minnimum Id like to go on this build.
The unit original came with a full AT sized PSU so I swapped it for a modernish small and quieter AT psu and added a new case speaker as the existing one fell to pieces (explains why no sound... bad glue):
Now I dont have many ISA 8 or 16bit cards left. Dont know where they went. Lost or stolen by movers perhaps, seems that happened to a bunch of our stuff looking back. I dont have any IDE controller boards so for now I have to use the Ultrastor card that came with it.
Turns out its na ESDI controller. I thought it was MFM because of the black faceplated Micropolis 1664-7 344mb 5.25" HDD. It works, but has a bunch of bad sectors. I am stuck with it for now. This is the setup program I got into using Debug. This is where I learned it was ESDI and this card wouldnt work with any of my MFM or RLL drives. It is also connected to a 1.44MB floppy and 1.2mb" 5.25" floppy, and a Qic-80 type tape backup... I think I should have a tape somehwere. Its been forever but Im going to leave it as I want to try it out again.
The first thing I did was install my complete in box 3com etherlink II card and configure the network so I can backup the data on the ESDI drive. Im guess its a fat 16 limitation but I can send to and pull from the machine from my home pc but not from the 486 (running WFW 3.11). Been so long I forget the rules. I copies the Hard drives contents up to the network. I ran the hard drive utilties on the card for almost a whole day. IT already had a bunch of bad sectors but found a couple more. IT was good to work the drive in. I Low level formatted it then setup the partition in FDISK. 326MB is OK but ID really like more storage and a cdrom. So I ordered this card from ebay so I can have IDE and add a cdrom for modern modern storage etc: https://www.ebay.com/itm/285685895932
That new ebay controller will allow me to get rid of this IO card as well:
Here is the Etherlink II. Maybe I can add the XTIDE universal bios onto the rom socket of the Etherlink ii??! What do you think?
