Hugo Holden
I have more information.
I received the first ADA1200 that I ordered. It came with a software tape from CMC. There are 6 "programs" on the tape.
It was a real trial to recover them from the tape (the dipoles must be fading) there were file name errors & load errors. But I used an old trick, by bending the spring arm in the cassette which forces the tape against the head harder (this increases the signal levels) I was able to recover all of the programs, they are:
CONTENTS
BAUD RATE
PLOT PROGRAM
FORMAT NUMBERS
SCREEN DUMP
DELAY ROUTINE.
The idea of the delay routine is to delay the serial data after a carriage return, long enough to allow the printer head to return to its home. This program is executed using SYS commands where the cassette buffers are.
CONTENTS
BAUD RATE
PLOT PROGRAM
FORMAT NUMBERS
SCREEN DUMP
DELAY ROUTINE.
