fxg
Hi guys,
I have a few things that I can't identify, but I have some pictures of them. If you have any clue, please post
1. 8bit ISA - apparently graphics adapter / LPT controller combo - all that I found written on the PCB is "MGP" and "Y-10" - nothing else. Well, the serial number, but that's kinda useless - it has two connectors: DB9 and DB25, both female. AMD chip is an AM9128-15PC [via Google I found that to be some kind of static RAM, but that doesn't tell me much] - the other 2 large ones are some UMC-built controllers, I guess for the DB25 port [LPT] photo
2. 16bit ISA - Some kind of "computer-on-a-card" with an Intel 486DX4 100MHz, 72pin SIMMs, etc... Nothing useful written on the card, I've searched everything and nothing conclusive. Photo
3. 16bit ISA - weird 5 port network card / switch? It has 5 RJ45 ports that are actually on the daughterboard. I've searched high and low for everything that was written on the card - no results. Photo 1, Photo 2, Photo 3
4. 16bit ISA - I have no idea what this could be. It has a single DB15 connector, 2 x 30pin SIMM slots and a bunch of chips that I've only seen the likes of on some video capture cards, but then what's with the DB15 connector? Maybe you have some ideea... Photo
Well, that's about it... I have some other I can't identify, but they're not that important [VLB graphics, ISA sound cards and I/O cards].
So, if you have any idea about these things... post, don't be shy
Cheers
Cheers
