Hugo Holden
I would agree, though it is interesting that the central error appears worse than the peripheral error (not common for a convergence error), or at least equal, and it is only on the H meridian, there is no vertical component to the error at all, which is often present with a pure convergence error,, which is possible with a pure convergence problem though, but it makes it a little more suspicious for a blue signal timing error as a possibility too. I still think it would pay to check the signal source, and if that was ok, then attempt to adjust the convergence error out with the magnetic rings.Red-blue convergence errors are most obvious when viewing magenta. In fact, when adjusting the red-blue convergence, I do it with a magenta pattern on the screen. The green tends to visually tie the red and blue together, even if they're pretty far off. If you look at the white border, you'll see that the left side of the line has a red shadow, and the right side has a blue shadow. It won't hurt anything (other than your eyes) to leave it as is, but I couldn't live with that much convergence error.
