tezza
This is a newbie question but I’ve tried to google an answer without success. I know some of you guys will know the answer to this straight off.
I’m mystified how logic ICs work with digital circuits carrying data? I know the principles of these ICs work i.e. how H or L inputs determine a certain output (either H or L) but what happens when a oscillating wave is used as input, as you would get in a computer circuit carrying data.
I’ve always assumed if a wave was used as an input, the output would also be a wave? If could be inverted or changed by other inputs but it would always be a wave. After all a wave is just a circuit oscillating between H and L except many times a second.
However recently I’ve been using an oscilloscope for diagnostic purposes and have discovered my assumption may be flawed. Take a TC40H139P IC. This is a dual decoder/multiplexer. Where a wave appears on ENABLE, or INPUT A or B, I would have expected a wave on all Y0-3 outputs? The exception being if ENABLE is steady H, in which case it doesn’t matter what A and B is, it will always be H.
This is not the case. When there is a Wave on either ENABLE, A or B, some of the outputs are a steady H and some are waves? I don’t know how to interpret truth tables with signals that carry a wave. I’d always assumed the signal would be flicking back and forth between H and L and the output would usually do so as well unless the truth table says it’s forced into a H unconditionally, by another input. This doesn’t always seem to be the case though.
Is someone able to explain it to me?
Tez
Tez
