offensive_Jerk
I had a post HERE about an issue with a 5170 fixed disk card being wonky. I had replaced the three caps on the bottom of the card just to try and see if that helped... It didn't.
It was advised to try the card in another machine which I was doing. This is a 5170 that I hardly use. The old Seagate was being cranky and noisy when I was first attempting to boot which I find these 5170s do to me. I have to "warm" up the hard drives for them to boot. This one squealed more than the others. I got a couple of 601 disk errors at boot, and then was able to boot the hard drive.
The machine booted, but failed reading a file and locked up. I rebooted and then the system locks up after posting. I figured command.com or something got corrupted on the lock up. I boot from floppy and ran Norton Disk Doctor and it marked some bad sectors. Then I rebooted again a few times and the 601 error went away.
Suddenly it wouldn't boot from the hard drive anymore. The last message I see on screen was a hard disk error of some sort (can't remember) and then smoke came billowing out of the computer. I had the top case off and it seemed to be coming out by the power supply.
I took the power supply apart and noticed what I believe to be filter caps are blown. One blue on appears outright blown, and damaged the nearby red colored cap. I also noticed the other blue cap has a crack in the center of it. Smelly smoke and lots of it.
Is there any problem with any of the computer's circuitry that would have caused these caps to blow? Could it have been the questionable Fixed Disk adapter that I replaced the caps on? Or something with the hard drive that maybe shorted the power supply since it suddenly stopped detecting at boot? I'm guessing the answer is no, since these are "line" capacitors but I really don't know anything about this stuff when it comes down to it.
Would I be alright just installing all new caps in this section of the power supply? It seems the other board on the PSU seems to have some questionable caps of the smaller physical size that appear somewhat bubbled out. Not sure how far I should go with this.
