leaknoil
I just picked up a as/400 system. I don't have any idea where to begin with it so, I'm asking some preemptive questions before I bother setting it all up.
The people that sold it to me were not only not helpful they were hostile. Seriously, they were real a**es. Came out of a rebar factory. I don't expect making rebar your whole life makes you a better person. These people were really unhappy.
Anyway, so it looks just like this minus the floppy drive
I didn't get the key and its in the 'secure' position. That going to bite me ? Are they generic keys like many other manufacturer's gear ?
Ok, so here's this big tan box. AFAIK, the only out is a single db25. It also came with a small IBM box called a 5394-01B. It has a 1.44mb floppy drive and an on/off switch. The back has a db25m and three large round 2 pin connectors.
I also got a few infowindow terminals. Three different styles but, most have a db25 and a db20 ? connector. I didn't count the smaller connectors pins. Looks about 20-18 and I'm too lazy to run back down stairs right now.
There are a ton of cables that came with this. None of which make much sense. Most related to the large 2 pin DIN style connector. I even got a couple strange heavy duty molded things that go from db25 to more of the 2pin things. Unless I'm missing it the cpu has none of these 2 pin connectors on it.
There is no chance I will ever get any question answered from these people. Passwords are out of the question if it has them. I am pretty sure they will hurl rebar at me if I try and go back. I don't think they like outsiders in their little rebar kingdom.
