Replacing the IBM 1.01 BIOS with the FD 3.61 BIOS should do you, can't say for sure, I don't have a ZuluSCSI. There is one annoyance with a Patriot in a system with no power plugs [50 and 70], you cannot easily find power for a SCSI device.
The ZuluSCSI can probably work just fine off the SCSI Termpower off the Patriot. To enable Termpwr, jumper W1 [between F1 and 50 pin SCSI header]. -BUT- if for some reason, it won't reliably work off Termpwr, you can solder a 4 pin Molex to J3, or solder in the wires onto the holes.
If you wandt the filtering caps,
C2,C5 - 16v 10uf electrolytic capacitors
C3,C4 - 16v 0.1uf Ceramic SMD Capacitors
Josh Behrends wendt through the trouble of measuring the MLCC SMD capacitors.
Original message ----------------////
Wanted to provide some missing information on the SCSI page under this section:
https://ardent-tool.com/SCSI/MCS.html#Patriot_Power
I own an MCS-700 SCSI adapter that has the capacitors which are missing on the IBM SCSI-2 "Patriot" SCSI adapter. In the picture posted on the site, the two electrolytic capacitors (C2 and C5) are 16v 10uf capacitors. I un-soldered one of the MLCC SMD capacitors (C3 and C4 )and measured it with my multimeter and they are 0.1uf and would probably be the same voltage of 16v.
