PhotoJim
So nope. Not listed.
See post #69 for the CH375DOS.sys driver that i use in my IBM XT 5160, It is v1.9A and the no-interupt version. It works but it's slow at around 18/Kb'sIs there another .SYS File I should use ? More 8086 Compatible ?
Hi,See post #69 for the CH375DOS.sys driver that i use in my IBM XT 5160, It is v1.9A and the no-interupt version. It works but it's slow at around 18/Kb's
I'll be happy to test if you post the driver.Hi,
I made a confusion, the code I saw is 8088 compatible.
If I patch the file and post it somebody can test ?
the Speed will be definitely MUCH Faster
Me too.. I have 2 of the boards in use right now in a 5150 and a 5160.I'll be happy to test if you post the driver.
Thanks but it's not working for me, The driver recognizes when a flash drive is NOT connected because it returns the "Drive not found" error, But when i connect a flash drive / CF or SD card in a USB adapter it just hangs for ever when trying to connect, I see some brief activity from the LED on the flash drive and that's it, It just hangs then.If you can try.
Be garefull, if the Read work and not the Write, it will crash your key.
I also added a text file with the assembly code I changed.
Ok, thanks.Thanks but it's not working for me, The driver recognizes when a flash drive is NOT connected because it returns the "Drive not found" error, But when i connect a flash drive / CF or SD card in a USB adapter it just hangs for ever when trying to connect, I see some brief activity from the LED on the flash drive and that's it, It just hangs then.
The driver you patched was v2.0A, I can't remember why i never used it but there was a reason, I have always used the v1.9A driver as it worked from the get go.
I posted the driver i use in this thread, See post #69, It's about 3KBOk, thanks.
What is the size of the working driver ?
I may wait for the boards to test myself....
Ok, So wait some more week so that I can play with this board.I posted the driver i use in this thread, See post #69, It's about 3KB
Beg pardon?Here is the new file, this time it is testes and working.
He's been patching/tweaking the driver.. see prior posts.Beg pardon?
Beg pardon?
How are you setting up your CF card or Flash drive ? and what size are they ?, What speed setting are you using ?Here is the new file, this time it is testes and working.
or typoes or English not being a first language. I knew why you said it. I just bypassed.Please look up every word in the passage I quoted--and then laugh at auto-correct.
