NicoleWallmow
Picked up a Dolch "LPAC 586" on fleabay for cheap, and got most everything going, but I am having some trouble with the display, the "Chips and Tech" driver that 98 is using by default only works in 16 color mode (640x480 or 800x600), I get garbage when I try to do higher color (256 at 800x600 and 256 or 16bit at 640x480). I am working on freeing up the glued/epoxied screws so I can get to the video card so I can grab full chipset model info off it, but I figured I would post now anyways in case someone who's familiar with Dolch might have an answer. I will edit this post or reply with chipset info once I can get past the epoxy/glued screws (I had to drill them out of the hard drive, but it was dead and I wasn't going to reuse it, so drilling it wasn't a problem, I don't want to drill the case/slot screws)
EDIT: Its a "Chips" F65545 chipset, here's a photo of the card
