tezza
A faulty 'track 0' switch is a possibility.
On initialisation, the floppy controller will look at the TRACK 00 line from the drive, and if that line indicates that the heads are not at track 0, will step the heads in the track 0 direction until the TRACK 00 line activates.
If the 'track 0' switch is faulty, then the TRACK 00 line will never activate. I would expect that after the floppy controller has issued 40 steps in the track 0 direction, and sees the TRACK 00 line still inactive, that the controller would then assume the drive to be faulty and stop any further operations with it.
Hmm..it keeps spinning though until CP/M itself stops it? Also, would a faulty track 0 switch be consistent with the stepper motor returning the head to a start position (edge of disk) on boot then doing nothing, and simply doing nothing if the head is already positioned at the start position?
I've swapped around the smaller card on the back of the drives and it seems both cards are fine too. So the "electronics" as such seem ok.
While I always like to know exactly what's wrong, I think the best course for me at this time is to look for a replacement FH SSDD drive.
Tez
