ef1j95
I've been having problems with a high current 78H05K regulator (the 5A, TO-3 version of the 7805) on an S-100 memory card. Took a gamble and bought three spares from Taiwan via ebay. They finally arrived, but after soldering one in, it failed immediately. It went into thermal shutdown. It never gets above 2V output from the 8V S-100 line.
I'm guessing these are fraudulently relabeled 7805K's. The parts that came were "mil-spec" which were different from what the seller showed online, which only further raises my suspicions.
The original 78H05K will provide a steady 5V for about a minute, but will drop as it heats up. I don't think it's due to anything more than the load of the fairly large number of chips on the card. There are no signs of shorts. No other hot parts, and I switched out the tantalum filter caps, which turned out fine.
I think my next step is to try one of the buck converter replacements.
