zander-san
- Joined
- Jan 21, 2024
- Messages
- 2
Hello all,
I am new to these fourms so please correct me on anything I do wrong in my post.
I have a 386 MSDOS 6.22 system, with a DE201 Ethernet card. I'm trying to get Microsoft Client working on but I seem to be running into an error while starting it up. From googling around I haven't found much info on it so I'm hoping someone here can tell me what it means so I can fix it.
I intend to use this to connect to a network drive I have made via samba on a linux machine for file exchanging and have no other uses for MS Client beyond that.
If the image below isn't viewable for some reason this is what happens:
On boot I eventually get stuck on "Initializing TCP/IP via DHCP... "
for 5 minutes until it eventually errors out and I get this error:
"No DHCP server found: TCP/IP not loaded
Unloadable TCP 1.0 not loaded.
NET0116: TCP access failure by Tiny RFC.
Tiny RFC 1.0 not loaded.
Press any key to cont inue
NET0116: TCP access failure by NMTSR.
Unloadable NMTSR 1.0 not loaded.
Error 7361: IPX or NetBIOS must be running in order to load the network
services."
Thank you to all and any who help!
services."
