Hunta
V1A Edit #2 9-Nov-84 Autor: G.Maier File: NOTE.TXT
M2RT11 Release Notes
This updated M2RT11 distribution kit contains a revised version
of the Modula-2 Compiler (M23) as well as the following additions
not described in INSTAL.TXT and GUIDE.TXT:
- M2C*.SYM: the symbol files of the compiler
- M2CDEF.COM: command file to compile the definition modules
M2C*.DEF of the compiler
- M2CMOD.COM: command file to compile M2C*.MOD
- M2CLNK.COM: command file to link a compiler which assumes FIS
- DB*.(TXT,DEF,MOD,SYM,LNK,COM): a new debugger for structured
data
- DECREF.MOD: a reference file decoder (new reference file syntax)
DBUG.TXT includes the informations needed additionaly to DEBUG.TXT to
install and use the new debugger for structured data which uses
a new reference syntax. Therefore, pass 2 (M2CP2) has to be linked
with the OLD implementation M2CREO.LNK of the module M2CREF, if the
OLD debugger is used. (The old debugger needs reference files generated
by M2CP2 linked with M2CREO.LNK, the new debugger needs reference
files generated by M2CP2 linked with M2CREF.LNK or M2CREN.LNK.)
Installation Instructions
__________________
Modula-2 system
The Modula-2 system is an implementation of the programming
language MODULA-2 on the PDP-11 computers. The system has been
developped by a group under the direction of Prof. N. Wirth at
the Institut fur Informatik of the ETH Zurich.
The responsibilities for the different parts of the system were
divided in the implementors group as follows:
Resident system : Christian Jacobi
Compiler : Leo Geissmann
Anton Gorrengourt
Christian Jacobi
Svend Erik Knudsen
Linker, Loader : Anton Gorrengourt
Christian Jacobi
Hans Heinrich Naegeli
Acknowledgement is also due to Urs Ammann, who contributed at
the compiler in the earlier stages of the project and to Andrea
Ventura, the author of the debugger module.
The author of this memo is Leo Geissmann.
Institut fur Informatik, ETH
CH-8092 Zurich
1. Requirements
____________
Hardware : PDP-11/40 (or other PDP-11 computers with the same
instruction set).
EIS option.
FIS or FPP option for real number arithmetics.
Emulation of EIS and/or FIS should be possible.
Optionally PDP-11/03 (LSI).
Operating system : RT-11SJ - V03 B, or RT-11SJ V04.00 .
data
__________________
Modula-2 system
Anton Gorrengourt
Christian Jacobi
Svend Erik Knudsen
Christian Jacobi
CH-8092 Zurich
1. Requirements
____________
instruction set).
EIS option.
