allmacs
I came across a thread by this Trixter individual , where he said that his computer stopped booting (like mine) when he cut out the battery.Here you have all technical documents, drivers, special M24 enabled software, ...
The battery is only for the realtime clock, nothing else. All hardware-configuration settings are done by DIP switches and Jumpers. Not needed for using the M24, as long as you don't need the actual date in your files.
But again looking for that thread to prove what was said again takes time away from other things I could be doing.
Maybe he found out in the course that the battery was not the cause of his symptoms.
Again I am following a different path now and having the other motherboard , video card and memory hopefully will aid me in comparing the components and their values.
