SomeGuy
Eventually you really should put an HTTP redirect in there.The hope is that the large message that I left on the front page will get folks over here, when they arrive at the previous version.
We shall see!
- Alex
We shall see!
- Alex
That's because there is no separate home page. Home is the forum, so that is what becomes highlighted. The tab could be dropped, as it's not needed.The "home" button doesn't seem to become active (white) after being clicked.
Fixed avatar...
is there a way to collapse that giant list of blogs? And, can the forum get a unique favicon?
What's needed is speculative, and an administrative issue. "Home" could have features like a collapsed display of forums and blogs; a user-help document link; the now ever-present rules-of-use document. In other words, a place of general or introductory, not specific,reference. In any event, when the home button is clicked, the button does not change to white/active (just to be clear on the question). What home could do is administrative. - regardsThat's because there is no separate home page. Home is the forum, so that is what becomes highlighted. The tab could be dropped, as it's not needed.
You probably didn't understand what I wrote. Home is just a link you provide and it's set to the forum's index page here. Yes, the link can be changed - but only to a page that exits already.In any event, when the home button is clicked, the button does not change to white/active
Well, it's two fold.If I mistakenly start a reply, where's the "Cancel" button to abandon it?
This is not personal about believing. I agree, I don't understand, because I don't know what to expect from XenForo operation. Because there's no user-documentation. I'll stop repeating "a lack of documentation". I clicked on xenforo.com's "home" - it took me to a home page of the Web site, that is out of all the forums. (shrug) I suggested previously, maybe a home-page could be constructed for purpose. I leave this matter to the admins. Thank you. - regards HerbYou probably didn't understand what I wrote. Home is just a link you provide and it's set to the forum's index page here. Yes, the link can be changed - but only to a page that exits already.
It's not going to ever become "white", as it's not a tab you can be "on". Check XenForo's own community forum if you don't believe me: https://xenforo.com/community/ (and click on Home)
First, if you start to reply and then just "go away", that's fine.
But if you come back to the thread, you'll find your "Draft" preloaded in the message are.
In the upper left is a "what's a floppy disk?" icon with an arrow. If you click on it, there's a "Delete Draft".
Hmmm. Seems conversations are contained with XenForo and are not actual emails. At best I found a profile option "alert me if my conversation gets a reply" or some such. Is that how "private messages" will work? I and recipient get a real-email alert? - regards Herb“Conversations” is the PM system, for XenForo.
- Alex
- Alex
The forum is set to keep drafts for 24 hours, after that they go away, but there is no cancel button, which is apparently a design choice on the part of Xenforo. The prescribed way to do this is to click on the little floppy and select "Delete Drafts" or just wait for the save draft to expire on it's own.Well, it's two fold.
I THINK this will remove the draft from being SAVED, but it doesn't clear the message area.
What I end up doing is simply select all and delete and then click "Delete Draft".
Best I've found so far.
