In the interest of making this board "period correct" using a single 5V 3A switching regulator in a TO-3 footprint (ie the EZSBC PSU5) wouid be out of the question?Anyone know a part number / source of the dual TO-220 heatsink of this style ?
EDIT Ah, Wakefield 680-5220
As standard the N* FPB uses two 7805's, the picture above is from a real board.In the interest of making this board "period correct" using a single 5V 3A switching regulator in a TO-3 footprint (ie the EZSBC PSU5) wouid be out of the question?
The chance of zero errors is pretty slim. It's still worth the effort.parts on their way. Found some SN74S571N for peanuts (75p each), just hope they are blank ! (and genuine) and most of the other IC's are ordered from Cricklewood and ones that were >£2 I have found on Ebay
Just need the final, final, final QA check then off to JCL
Bet it doesn't work...
Yes, with the dazzler we found a couple of tracks I had missed to ground, but at least they were an easy fix.The chance of zero errors is pretty slim. It's still worth the effort.
Troubleshooting is going to be .... interesting ;^)
Sorry, I see what your getting at. The two TO-220's is what it uses but your right, would be a good idea. Could use a heatsink that looks identical with one of these in the middle. Will look into it.In the interest of making this board "period correct" using a single 5V 3A switching regulator in a TO-3 footprint (ie the EZSBC PSU5) wouid be out of the question?
Switch-mode regulators run cooler, are more efficient and generally have better regulation. There are several vendors of drop-in replacements for the 78xx TO-220 jobs. The only downside is a bit of low-level noise at the switching frequency (mostly matters in audio circuits). You can also get rid of that big heatsink.SMPS... YUCK
if I cared about heat production and efficiency I would not be interested in vintage computingSwitch-mode regulators run cooler, are more efficient and generally have better regulation. There are several vendors of drop-in replacements for the 78xx TO-220 jobs. The only downside is a bit of low-level noise at the switching frequency. You can also get rid of that big heatsink.
Be careful of EZSBC. I ordered one of those high current TO-3 footprint regulators (quite expensive, BTW) from them a while back to replace the regulator on an ADC Super Six. It failed on first power up. I tried to get help or advice from EZSBC about the problem, but all my communication attempts went unanswered. Not even an offer to replace the failed part. I'll never buy anything from them again. Use Polu (sp?).In the interest of making this board "period correct" using a single 5V 3A switching regulator in a TO-3 footprint (ie the EZSBC PSU5) wouid be out of the question?
