For the measurement points I measure all voltages at the different pins on the backplane, not at the PSU's output. This is also true for the Scope. I connect the red multimeter lead to the pins that have the voltage, and I connect the common probe to the chassis. I do, however, connect the dummy load directly to the output of the PSU.
Placing the load point near the supply is ok. Where do the sense leads attach? (missed that detail)
Measuring from the backplane - particularly the furthest end is the best point to measure (is that where the CIM would usually be?) however, it would be best to place the minus test lead on the backplane in as close proximity to the positive lead as practical. I know is seems a trivial difference, but with heavy currents running it will be important. (That's why there are both positive and negative sense leads)
Ray's transistor / heatsink dummy load is clever, but it's really only worthwhile if he got those parts by scavenging what he had, not if he had to go procure them.
Another thing to think about is # 12 copper wires is about 1 ohm per thousand feet so a 100 foot roll of #12 will look like a 0.1 Ohm resistor and may be easer to connect in.
This is a good idea for a short term load, but I'm afraid it will heat too quickly and turn the #12 wire into a fuse link. (that's 50amps 250W). I would be much more comfortable if that were #12 Romex, and he used it as a loop.
+5V power in on BLACK at the near end, Wire nut BLACK to WHITE on the far end, and wire nut WHITE to GROUND on the near end (where BLACK is fed) and then the GROUND lead (uninsulated wire) on the far end to the 5V Return side.
That would be 0.3Ω (16.6A 83W) and be underneath the wire's safe current rating. (I'd probably still keep the wire loop in a bucket of water or ice)
If that doesn't present a heating problem, you could then progress to a 0.2Ω (25A 125W) load by using the near WHITE as the return point.
NOTE: Do not let water enter the open ends of the wire's jacket or pierce the jacket anywhere. You will still be able to use it for it's original purpose if it's not compromised.
Hope that's clear.
That is probably better than a cigarette lighter, which is only about 1.2Ω hot, I come to find out.
Also, I don't think I'd add that load
after the unit was powered. I'd have it attached before hand. If the supply trips immediately when you try it, don't try again.
Found a TM on the BA11-A (I think you guys were already reading it)
