AK6DN
Hi All;
Don, Thank You for Your Response..
This is a Cygwin 32 bit build, and Not a 64 bit build..
I don't have any of the -64 components in it..
That is 'Why" went to all of the Trouble of Deleting Both of my former Builds and Going with Just the 32 bit build that I currently have.. Just as You told and suggested for me to do.. I have tried to do as You tell me. so that it would work and not be a problem for either of us..
I am Sorry that You thought I still had the 64 bit build, I even stated in my former postings that I was going to do a Rebuild..
THANK YOU Marty
Sorry, when you said this:
As, I have completely Deleted Cygwin32..
Give me awhile to re-load it..
I guess Not !!
I inferred that you were going back to your original 64b CYGWIN environment.
In any event, I still can't explain why your 'make' and the compile with GCC would hang. I have never seen that happen, and don't know what might be causing that, or a solution.
I guess I might try running the GCC compile commands manually instead of under control of 'make' to see whether it is 'make' or 'GCC' that is having the problem.
Don
