DougIngraham
Dave,
You are right unless the program you are writing is for an obfuscated C contest.
Doug,I finally got back to working on console serial disk a few days ago. I think I had been suffering from burnout after spending a week working on an old Straight 8 (not mine) and getting it sort of running.
One problem I had was with Unix termios and putting the console keyboard/display in raw mode. This now seems to be working (at least on Linux) and I even think I know what I am doing....
The bug I squashed last night was one of those things I probably knew 40 years ago. Here is the snippit of C code that I eventually found was failing.
This is supposed to take the character received from the pdp8 and decide if it is the server wakeup code. The server wakeup code is 020 through 027 where the last octal digit is the callers instruction field. The do_server routine uses the field to know what field to look in to find the handler call argument list. This test was always false even when pdp_ch was set to a value of 021. Do you see what the problem is? Took me several hours of looking in the wrong place before I realized do_server was never being called. What is supposed to happen is the AND with 0370 will remove the field bits from the comparison. That is not what was happening. The C precedence rules cause the == to take place before the & so 0370 is never equal to 020 giving a result of 0 which when ANDed with anything is still 0. which means do_server was never being called.C:if( pdp_ch&0370 == 020 ) do_server( pdp_ch&007 );
Is the working business.C:if( (pdp_ch&0370) == 020 ) do_server( pdp_ch*007 );
Now to find the next bug!
/ GET A 12 BIT VALUE FROM THE SERVER
GET12, .-.
KSF /WAIT FOR A CHARACTER
JMP .-1
KRB /READ IN THE CHARACTER
RTL /SHIFT LEFT 4 BITS
RTL
DCA TEMP /SAVE UPPER 8 BITS
KSF /WAIT FOR LOWER 4 BITS
JMP .-1
KRB /READ IN THE LOWER 4 BITS
TAD TEMP /COMBINE
JMP I GET12 /RETURN
0025 Load Addr
6031 Dep
5025 Dep
6036 Dep
7012 Dep
7010 Dep
3001 Dep
2032 Dep
5025 Dep
0025 Load Addr
Clear
Cont
dpi@raspberrypi:~/consd/server $ ./csd -D
SERVER: Debug mode enabled. Command line:
./csd -D
Opening system image system.dsk
SERVER: Opening system image system.dsk
SERVER: Reading the system image into memory.
SERVER: Calculating installed handler checksum.
SERVER: system.dsk appears to have an RK05 handler installed
Continuing anyway....
SERVER: Verifying the boot code on the boot block
Patching the boot code then testing it so it has to match.
SERVER: Examining the OS/8 entry point on the boot block
SERVER: Verifying the handler on the boot block
Patching the handler code then testing it so it has to match.
SERVER: sending 21 bytes of boot2 help code
SERVER: sending the boot block
SERVER: do_server called with field=1
SERVER: do_server waiting for called address
SERVER: do_server the passed handler entry point is 07611
SERVER: do_server waiting for the keyboard input character buffer.
SERVER: do_server the keyboard buffer character=000
SERVER: mem_read called F=0, A=7607, C=0001
SERVER: do_server arg list Field=1 address=07671
SERVER: do_server fetching the argument list
SERVER: mem_read called F=1, A=7671, C=0003
SERVER: do_server dumping the callers argument list
arg0=1000
arg1=0000
arg2=0007
The fact that the initial request is 4 blocks starting at 7 and 007, 010, 011, and 012 are the keyboard monitor seems like a good thing. I will verify that if possible. It has been a while since I looked at what is in the system area and where so I am trusting you on that.Isn't 07-12 (all numbers in OCTAL) the keyboard monitor with 13-15 being USR and 16 being the first device handler?
Is it worth dumping the first 'n' blocks of the disk image you are using to see what you have on there - so we all have the same frame of reference?
Block=007
0000: 0003 7200 1053 3033 4500 2331 2324 0515
0010: 4005 2222 0000 1051 7764 1723 7523 0000
0020: 0000 7771 7700 0200 1200 0211 7607 5372
0030: 6203 0321 1630 0402 0203 4562 1161 5400
0040: 1160 7610 5046 3445 5001 7777 6263 5450
0050: 5601 1664 6544 7605 4000 3700 2020 0070
0060: 0603 0600 0434 0067 6003 0244 0100 0336
0070: 0334 7001 6670 0212 0215 0403 0010 7700
0100: 0330 0306 0564 1754 0527 0300 1676 7404
0110: 7600 7402 7401 7403 1610 7400 0526 0200
0120: 0007 7757 7764 7762 0033 7761 7760 7756
0130: 7775 7745 1672 1000 7744 1113 0370 1001
0140: 0645 1532 2326 0651 1645 7410 0766 1600
0150: 0637 1655 0701 1163 7740 0012 1327 0363
0160: 0777 1166 7607 0256 0004 0077 7772 7746
0170: 7477 7766 7776 7522 0240 7540 0034 7000
0200: 5706 5204 6041 5202 6046 7200 1177 3201
0210: 5600 0000 3034 3035 3036 3037 1176 3044
0220: 7240 3045 3043 1413 1175 7450 5223 1174
0230: 7410 1413 3031 1031 1173 7450 5275 1172
0240: 7100 1171 7620 5252 1170 1031 7120 1167
0250: 7620 5302 1043 1166 7700 5231 1043 7110
0260: 1044 3040 1031 0165 7430 5271 7006 7006
0270: 7006 1440 3440 2043 5231 2045 5302 2044
0300: 1164 5222 1043 7640 2211 5611 4000 1034
0310: 4340 1035 4340 1036 4340 1037 7650 5706
0320: 1163 4352 1037 4340 5706 4340 2330 7410
0330: 0000 7200 1730 7440 5325 6041 5335 5433
0340: 0000 3031 1031 7012 7012 7012 4352 1031
0350: 4352 5740 0000 0165 7450 5752 1174 0165
0360: 1174 4423 5752 4330 7700 0000 5337 1400
0370: 1413 7450 5767 4562 0201 0400 0054 5001
Block=010
0000: 5705 0000 4561 4424 1160 3013 4425 7000
0010: 4556 7655 0436 5477 0545 5553 0512 7073
0020: 0511 5600 0455 5454 0600 6074 0573 7777
0030: 1151 7377 1367 0000 5635 1362 1155 4265
0040: 1154 3041 4425 5254 1035 7450 5253 1034
0050: 7004 7230 1035 1034 5553 3552 1030 4551
0060: 2046 1162 3305 7201 5320 0000 3302 4550
0070: 4425 5547 1034 3303 1035 3304 1364 3305
0100: 6212 4422 0001 0000 0000 1005 5546 1304
0110: 5665 1145 3552 1030 4551 3046 7201 4265
0120: 4332 4550 1050 6212 4422 0002 0034 7626
0130: 5544 5543 0000 3050 1305 3026 4425 5547
0140: 1037 7450 1142 3037 5732 1141 3033 1567
0150: 4551 6212 4727 1013 1140 3013 1137 3364
0160: 7201 4265 4332 5536 7001 4562 4600 6200
0170: 0035 5001 5764 4432 4562 1001 0000 0060
0200: 3040 3021 1413 7440 5535 1534 3566 1567
0210: 0133 7640 5532 1567 4551 1531 3530 6041
0220: 5217 4432 1567 7710 5566 1162 3527 1133
0230: 3526 3525 1124 3523 1027 3522 5521 0000
0240: 6212 4422 0010 6211 3520 6201 1117 3022
0250: 5637 1516 3256 4426 0101 7400 0000 5001
0260: 1515 4514 1513 7004 4451 1512 3566 1511
0270: 3530 1512 3534 1511 3531 1513 4551 1027
0300: 3522 7410 5307 1030 3566 1110 3530 1515
0310: 7144 1107 3041 1441 3525 2041 1026 1117
0320: 7204 1441 0165 7640 5506 1525 7130 1441
0330: 1105 7510 5323 1110 7500 2504 1105 3345
0340: 1504 7040 1256 3347 4426 0000 6200 0000
0350: 5503 4502 3351 2046 3522 1345 7041 1441
0360: 7550 2515 7410 5522 3441 5307 4501 4500
0370: 4016 1724 4001 2601 1114 0102 1405 0000
Block=011
0000: 0300 0311 0316 0311 0324 6211 2477 5212
0010: 1117 3022 6201 1413 3414 2021 5213 6211
0020: 1263 3662 2220 2262 2261 5220 6201 1663
0030: 7004 7700 5241 3650 1567 0251 7650 5035
0040: 5046 1117 6034 1375 7650 6031 5433 5306
0050: 1731 0400 4207 0300 7000 0035 7402 6203
0060: 6042 7764 7626 7777 1637 3640 2237 2240
0070: 2241 5227 6203 5626 1000 1645 7666 6211
0100: 1251 3741 6201 3205 6046 5766 6032 5710
0110: 1273 1032 1413 1377 7100 1076 3042 7420
0120: 5330 4341 4341 4341 1021 1042 3021 5312
0130: 1040 0120 7106 7004 1361 3566 1021 5740
0140: 0616 7677 1021 7104 3021 1040 7004 3040
0150: 5741 1154 3014 1125 3041 6211 3414 2041
0160: 5356 6203 5475 6211 3441 5361 0404 1074
0170: 3034 4776 1073 4423 5766 7575 1262 7510
0200: 0404 1163 4423 3020 1160 3013 3017 6031
0210: 5207 1117 6034 3034 6032 4327 7553 1273
0220: 7563 1252 7401 1307 7555 1207 7557 1207
0230: 7545 1302 7566 1207 7600 1207 7561 1207
0240: 7575 1273 0000 4262 1034 3413 1013 1072
0250: 7710 5207 4561 1013 1071 7650 5201 3413
0260: 3413 5600 0000 1034 5344 1070 4423 3020
0270: 1034 4423 5662 1067 4423 1034 1066 4423
0300: 4561 5201 1065 3034 4262 2017 5253 1013
0310: 1071 7650 5300 0210 1313 4423 1324 4423
0320: 1013 3040 1313 4423 7240 1013 5205 0000
0330: 1727 2327 7450 5727 1034 7650 5341 2327
0340: 5330 1727 3040 5440 1354 7500 1353 1352
0350: 3034 5270 0340 7740 7440 4423 5352 4501
0360: 5557 0000 1064 4551 1063 3375 5372 1031
0370: 7650 5462 4562 0201 0400 0055 5001 5461
Block=012
0000: 4562 0201 0400 0037 5001 1060 3017 1461
0010: 3041 1041 4514 2017 1417 4776 1241 3241
0020: 2041 5213 1241 7106 7006 1050 6212 4422
0030: 0003 0034 0000 5367 1050 6212 4422 0004
0040: 0034 0001 5367 1060 3017 4432 1567 7004
0050: 7040 7720 4343 1231 3360 4354 1417 3357
0060: 7330 1417 3356 1357 7004 7730 5327 1356
0070: 0057 7640 5327 4343 7240 1356 7104 1357
0100: 7004 7730 5306 1356 1076 5326 1356 3041
0110: 1357 7041 1056 7130 3356 4354 7332 3357
0120: 1356 0055 7041 1041 7500 1054 3356 4354
0130: 2461 5256 4562 0610 0000 0013 5001 7240
0140: 6211 3477 5453 0000 2350 5743 4562 1010
0150: 7777 0033 5001 5743 0000 4426 4101 0600
0160: 0000 5367 1356 4776 1360 3360 5754 4500
0170: 2301 2605 4005 2222 1722 0000 1765 7110
0200: 4500 2417 1740 0605 2740 0122 0723 0000
0210: 0000 7040 0154 7650 5610 1053 3033 4500
0220: 0317 2205 4011 1501 0705 4005 2222 0000
0230: 0000 1567 7010 7200 1022 7730 5630 6212
0240: 4422 0011 1077 3022 5630 4501 4500 4016
0250: 1724 4006 1725 1604 0000 0000 3567 4550
0260: 6212 4422 0013 5655 0000 0743 0117 7650
0270: 5664 5215 4500 1617 4141 0000 1441 3526
0300: 1046 7650 4502 1722 3742 1722 7001 3344
0310: 1026 3527 1026 3364 1415 3416 2323 5314
0320: 5721 7524 0656 7724 2761 5334 1344 3762
0330: 6041 5330 5733 7757 1760 3343 2360 1760
0340: 3342 4764 7747 7771 0000 5354 1342 4365
0350: 1344 3344 2360 5324 6212 4763 0007 0000
0360: 7404 7400 7762 7700 0000 0000 7112 7012
0370: 7012 0377 7450 1377 7001 7110 5765 0037
Block=007
0000: 0003 7200 1053 3033 4500 2331 2324 0515 C : H+ X[ % SY ST EM
0010: 4005 2222 0000 1051 7764 1723 7523 0000 E RR H) ?4 OS =S
0020: 0000 7771 7700 0200 1200 0211 7607 5372 ?9 ? B J BI >G +:
0030: 6203 0321 1630 0402 0203 4562 1161 5400 2C CQ NX DB BC %2 I1 ,
0040: 1160 7610 5046 3445 5001 7777 6263 5450 I0 >H (& \% (A ?? 23 ,(
0050: 5601 1664 6544 7605 4000 3700 2020 0070 .A N4 5$ >E _ PP 8
0060: 0603 0600 0434 0067 6003 0244 0100 0336 FC F D\ 7 0C B$ A C^
0070: 0334 7001 6670 0212 0215 0403 0010 7700 C\ 8A 68 BJ BM DC H ?
0100: 0330 0306 0564 1754 0527 0300 1676 7404 CX CF E4 O, EW C N> <D
0110: 7600 7402 7401 7403 1610 7400 0526 0200 > <B <A <C NH < EV B
0120: 0007 7757 7764 7762 0033 7761 7760 7756 G ?/ ?4 ?2 [ ?1 ?0 ?.
0130: 7775 7745 1672 1000 7744 1113 0370 1001 ?= ?% N: H ?$ IK C8 HA
0140: 0645 1532 2326 0651 1645 7410 0766 1600 F% MZ SV F) N% <H G6 N
0150: 0637 1655 0701 1163 7740 0012 1327 0363 F_ N- GA I3 ? J KW C3
0160: 0777 1166 7607 0256 0004 0077 7772 7746 G? I6 >G B. D ? ?: ?&
0170: 7477 7766 7776 7522 0240 7540 0034 7000 <? ?6 ?> =R B = \ 8
0200: 5706 5204 6041 5202 6046 7200 1177 3201 /F *D 0! *B 0& : I? ZA
0210: 5600 0000 3034 3035 3036 3037 1176 3044 . X\ X] X^ X_ I> X$
0220: 7240 3045 3043 1413 1175 7450 5223 1174 : X% X# LK I= <( *S I<
0230: 7410 1413 3031 1031 1173 7450 5275 1172 <H LK XY HY I; <( *= I:
0240: 7100 1171 7620 5252 1170 1031 7120 1167 9 I9 >P ** I8 HY 9P I7
0250: 7620 5302 1043 1166 7700 5231 1043 7110 >P +B H# I6 ? *Y H# 9H
0260: 1044 3040 1031 0165 7430 5271 7006 7006 H$ X HY A5 <X *9 8F 8F
0270: 7006 1440 3440 2043 5231 2045 5302 2044 8F L \ P# *Y P% +B P$
0300: 1164 5222 1043 7640 2211 5611 4000 1034 I4 *R H# > RI .I H\
0310: 4340 1035 4340 1036 4340 1037 7650 5706 # H] # H^ # H_ >( /F
0320: 1163 4352 1037 4340 5706 4340 2330 7410 I3 #* H_ # /F # SX <H
0330: 0000 7200 1730 7440 5325 6041 5335 5433 : OX < +U 0! +] ,[
0340: 0000 3031 1031 7012 7012 7012 4352 1031 XY HY 8J 8J 8J #* HY
0350: 4352 5740 0000 0165 7450 5752 1174 0165 #* / A5 <( /* I< A5
0360: 1174 4423 5752 4330 7700 0000 5337 1400 I< $S /* #X ? +_ L
0370: 1413 7450 5767 4562 0201 0400 0054 5001 LK <( /7 %2 BA D , (A
Block=010
0000: 5705 0000 4561 4424 1160 3013 4425 7000 /E %1 $T I0 XK $U 8
0010: 4556 7655 0436 5477 0545 5553 0512 7073 %. >- D^ ,? E% -+ EJ 8;
0020: 0511 5600 0455 5454 0600 6074 0573 7777 EI . D- ,, F 0< E; ??
0030: 1151 7377 1367 0000 5635 1362 1155 4265 I) ;? K7 .] K2 I- "5
0040: 1154 3041 4425 5254 1035 7450 5253 1034 I, X! $U *, H] <( *+ H\
0050: 7004 7230 1035 1034 5553 3552 1030 4551 8D :X H] H\ -+ ]* HX %)
0060: 2046 1162 3305 7201 5320 0000 3302 4550 P& I2 [E :A +P [B %(
0070: 4425 5547 1034 3303 1035 3304 1364 3305 $U -' H\ [C H] [D K4 [E
0100: 6212 4422 0001 0000 0000 1005 5546 1304 2J $R A HE -& KD
0110: 5665 1145 3552 1030 4551 3046 7201 4265 .5 I% ]* HX %) X& :A "5
0120: 4332 4550 1050 6212 4422 0002 0034 7626 #Z %( H( 2J $R B \ >V
0130: 5544 5543 0000 3050 1305 3026 4425 5547 -$ -# X( KE XV $U -'
0140: 1037 7450 1142 3037 5732 1141 3033 1567 H_ <( I" X_ /Z I! X[ M7
0150: 4551 6212 4727 1013 1140 3013 1137 3364 %) 2J 'W HK I XK I_ [4
0160: 7201 4265 4332 5536 7001 4562 4600 6200 :A "5 #Z -^ 8A %2 & 2
0170: 0035 5001 5764 4432 4562 1001 0000 0060 ] (A /4 $Z %2 HA 0
0200: 3040 3021 1413 7440 5535 1534 3566 1567 X XQ LK < -] M\ ]6 M7
0210: 0133 7640 5532 1567 4551 1531 3530 6041 A[ > -Z M7 %) MY ]X 0!
0220: 5217 4432 1567 7710 5566 1162 3527 1133 *O $Z M7 ?H -6 I2 ]W I[
0230: 3526 3525 1124 3523 1027 3522 5521 0000 ]V ]U IT ]S HW ]R -Q
0240: 6212 4422 0010 6211 3520 6201 1117 3022 2J $R H 2I ]P 2A IO XR
0250: 5637 1516 3256 4426 0101 7400 0000 5001 ._ MN Z. $V AA < (A
0260: 1515 4514 1513 7004 4451 1512 3566 1511 MM %L MK 8D $) MJ ]6 MI
0270: 3530 1512 3534 1511 3531 1513 4551 1027 ]X MJ ]\ MI ]Y MK %) HW
0300: 3522 7410 5307 1030 3566 1110 3530 1515 ]R <H +G HX ]6 IH ]X MM
0310: 7144 1107 3041 1441 3525 2041 1026 1117 9$ IG X! L! ]U P! HV IO
0320: 7204 1441 0165 7640 5506 1525 7130 1441 :D L! A5 > -F MU 9X L!
0330: 1105 7510 5323 1110 7500 2504 1105 3345 IE =H +S IH = UD IE [%
0340: 1504 7040 1256 3347 4426 0000 6200 0000 MD 8 J. [' $V 2
0350: 5503 4502 3351 2046 3522 1345 7041 1441 -C %B [) P& ]R K% 8! L!
0360: 7550 2515 7410 5522 3441 5307 4501 4500 =( UM <H -R \! +G %A %
0370: 4016 1724 4001 2601 1114 0102 1405 0000 N OT A VA IL AB LE
Block=011
0000: 0300 0311 0316 0311 0324 6211 2477 5212 C CI CN CI CT 2I T? *J
0010: 1117 3022 6201 1413 3414 2021 5213 6211 IO XR 2A LK \L PQ *K 2I
0020: 1263 3662 2220 2262 2261 5220 6201 1663 J3 ^2 RP R2 R1 *P 2A N3
0030: 7004 7700 5241 3650 1567 0251 7650 5035 8D ? *! ^( M7 B) >( (]
0040: 5046 1117 6034 1375 7650 6031 5433 5306 (& IO 0\ K= >( 0Y ,[ +F
0050: 1731 0400 4207 0300 7000 0035 7402 6203 OY D "G C 8 ] <B 2C
0060: 6042 7764 7626 7777 1637 3640 2237 2240 0" ?4 >V ?? N_ ^ R_ R
0070: 2241 5227 6203 5626 1000 1645 7666 6211 R! *W 2C .V H N% >6 2I
0100: 1251 3741 6201 3205 6046 5766 6032 5710 J) _! 2A ZE 0& /6 0Z /H
0110: 1273 1032 1413 1377 7100 1076 3042 7420 J; HZ LK K? 9 H> X" <P
0120: 5330 4341 4341 4341 1021 1042 3021 5312 +X #! #! #! HQ H" XQ +J
0130: 1040 0120 7106 7004 1361 3566 1021 5740 H AP 9F 8D K1 ]6 HQ /
0140: 0616 7677 1021 7104 3021 1040 7004 3040 FN >? HQ 9D XQ H 8D X
0150: 5741 1154 3014 1125 3041 6211 3414 2041 /! I, XL IU X! 2I \L P!
0160: 5356 6203 5475 6211 3441 5361 0404 1074 +. 2C ,= 2I \! +1 DD H<
0170: 3034 4776 1073 4423 5766 7575 1262 7510 X\ '> H; $S /6 == J2 =H
0200: 0404 1163 4423 3020 1160 3013 3017 6031 DD I3 $S XP I0 XK XO 0Y
0210: 5207 1117 6034 3034 6032 4327 7553 1273 *G IO 0\ X\ 0Z #W =+ J;
0220: 7563 1252 7401 1307 7555 1207 7557 1207 =3 J* <A KG =- JG =/ JG
0230: 7545 1302 7566 1207 7600 1207 7561 1207 =% KB =6 JG > JG =1 JG
0240: 7575 1273 0000 4262 1034 3413 1013 1072 == J; "2 H\ \K HK H:
0250: 7710 5207 4561 1013 1071 7650 5201 3413 ?H *G %1 HK H9 >( *A \K
0260: 3413 5600 0000 1034 5344 1070 4423 3020 \K . H\ +$ H8 $S XP
0270: 1034 4423 5662 1067 4423 1034 1066 4423 H\ $S .2 H7 $S H\ H6 $S
0300: 4561 5201 1065 3034 4262 2017 5253 1013 %1 *A H5 X\ "2 PO *+ HK
0310: 1071 7650 5300 0210 1313 4423 1324 4423 H9 >( + BH KK $S KT $S
0320: 1013 3040 1313 4423 7240 1013 5205 0000 HK X KK $S : HK *E
0330: 1727 2327 7450 5727 1034 7650 5341 2327 OW SW <( /W H\ >( +! SW
0340: 5330 1727 3040 5440 1354 7500 1353 1352 +X OW X , K, = K+ K*
0350: 3034 5270 0340 7740 7440 4423 5352 4501 X\ *8 C ? < $S +* %A
0360: 5557 0000 1064 4551 1063 3375 5372 1031 -/ H4 %) H3 [= +: HY
0370: 7650 5462 4562 0201 0400 0055 5001 5461 >( ,2 %2 BA D - (A ,1
Block=012
0000: 4562 0201 0400 0037 5001 1060 3017 1461 %2 BA D _ (A H0 XO L1
0010: 3041 1041 4514 2017 1417 4776 1241 3241 X! H! %L PO LO '> J! Z!
0020: 2041 5213 1241 7106 7006 1050 6212 4422 P! *K J! 9F 8F H( 2J $R
0030: 0003 0034 0000 5367 1050 6212 4422 0004 C \ +7 H( 2J $R D
0040: 0034 0001 5367 1060 3017 4432 1567 7004 \ A +7 H0 XO $Z M7 8D
0050: 7040 7720 4343 1231 3360 4354 1417 3357 8 ?P ## JY [0 #, LO [/
0060: 7330 1417 3356 1357 7004 7730 5327 1356 ;X LO [. K/ 8D ?X +W K.
0070: 0057 7640 5327 4343 7240 1356 7104 1357 / > +W ## : K. 9D K/
0100: 7004 7730 5306 1356 1076 5326 1356 3041 8D ?X +F K. H> +V K. X!
0110: 1357 7041 1056 7130 3356 4354 7332 3357 K/ 8! H. 9X [. #, ;Z [/
0120: 1356 0055 7041 1041 7500 1054 3356 4354 K. - 8! H! = H, [. #,
0130: 2461 5256 4562 0610 0000 0013 5001 7240 T1 *. %2 FH K (A :
0140: 6211 3477 5453 0000 2350 5743 4562 1010 2I \? ,+ S( /# %2 HH
0150: 7777 0033 5001 5743 0000 4426 4101 0600 ?? [ (A /# $V !A F
0160: 0000 5367 1356 4776 1360 3360 5754 4500 +7 K. '> K0 [0 /, %
0170: 2301 2605 4005 2222 1722 0000 1765 7110 SA VE E RR OR O5 9H
0200: 4500 2417 1740 0605 2740 0122 0723 0000 % TO O FE W AR GS
0210: 0000 7040 0154 7650 5610 1053 3033 4500 8 A, >( .H H+ X[ %
0220: 0317 2205 4011 1501 0705 4005 2222 0000 CO RE I MA GE E RR
0230: 0000 1567 7010 7200 1022 7730 5630 6212 M7 8H : HR ?X .X 2J
0240: 4422 0011 1077 3022 5630 4501 4500 4016 $R I H? XR .X %A % N
0250: 1724 4006 1725 1604 0000 0000 3567 4550 OT F OU ND ]7 %(
0260: 6212 4422 0013 5655 0000 0743 0117 7650 2J $R K .- G# AO >(
0270: 5664 5215 4500 1617 4141 0000 1441 3526 .4 *M % NO !! L! ]V
0300: 1046 7650 4502 1722 3742 1722 7001 3344 H& >( %B OR _" OR 8A [$
0310: 1026 3527 1026 3364 1415 3416 2323 5314 HV ]W HV [4 LM \N SS +L
0320: 5721 7524 0656 7724 2761 5334 1344 3762 /Q =T F. ?T W1 +\ K$ _2
0330: 6041 5330 5733 7757 1760 3343 2360 1760 0! +X /[ ?/ O0 [# S0 O0
0340: 3342 4764 7747 7771 0000 5354 1342 4365 [" '4 ?' ?9 +, K" #5
0350: 1344 3344 2360 5324 6212 4763 0007 0000 K$ [$ S0 +T 2J '3 G
0360: 7404 7400 7762 7700 0000 0000 7112 7012 <D < ?2 ? 9J 8J
0370: 7012 0377 7450 1377 7001 7110 5765 0037 8J C? <( K? 8A 9H /5 _
/* since we are having no luck lets test pdp_mem_write
** by doing an address test with it. Fill a buffer with
** 0000 through 7777 and write it to field 2
fprintf( stderr, "address test write\r\n" );
for( i=0000; i<=07777; i++) tstbuff[i]=i;
pdp_mem_write( 2, 0000, 4096, tstbuff );
fprintf( stderr, "address test readback\r\n" );
for( i=0000; i<=07777; i++) tstbuff[i]= -1;
pdp_mem_read( 2, 0000, 4096, tstbuff );
for( i=0000; i<=07777; i++) if( tstbuff[i]!=i )
fprintf(stderr, "SERVER: TSTWRT i=%04o got=%04o\r\n", i, tstbuff[i]);
fprintf( stderr, "address test complete\r\n" );
tty_reset();
pdp_reset();
exit(1);
I hope you are one of those people for whom Covid turns out to be not that big of a deal.Sorry I haven't got back to you. I tested positive for Covid on Sunday - so I am locked up in the spare bedroom now with only a phone and works laptop for company.
Anyhow, I was wondering exactly the same as to why the HALT was occurring at a place where it shouldn't be executing. The KBD handler, USR etc. are all supposed to be loaded up 'high' in fields 0 and 1 (7600...).
Does it make sense to publish your current '8' bootstrap and server code so that you can have a fresh pair of eyes look at them - or at least make suggestions regarding how to track down the bugs.
/ CONSOLE SERIAL DISK OS/8 HELP BOOT Page 1
1 / CONSOLE SERIAL DISK OS/8 HELP BOOT
2 /
3 /VER 0.1 20220428 HAD AN IDEA TO SIMPLIFY AND MAKE IT LOOK MORE LIKE THE
4 / REGULAR BOOT2 PROGRAMS EMBEDDED IN THE BOOT BLOCK.
5 /
6 / (C) COPYRIGHT 2022 BY DOUG INGRAHAM. NO RIGHTS RESERVED. FEEL FREE TO USE
7 / THIS CODE FOR ANYTHING YOU WANT.
8 /
9 / BOOT2 IS UNUSUAL BECAUSE IT IS LIMITED BY THE CONSTRAINTS OF THE HELP
10 / LOADER. THESE CONSTRAINTS ARE:
11 /
12 / * MEMORY REFERENCE INSTRUCTIONS CAN ONLY DIRECTLY ADDRESS MEMORY FROM
13 / 000 THROUGH 037. NO INDIRECT OR CURRENT PAGE REFERENCES!
14 / * IOT'S CAN ONLY ADDRESS DEVICE CODES 0 THROUGH 3.
15 / * FOR THE OPERATE INSTRUCTIONS YOU CAN ONLY GENERATE GROUP 1 AND NOT
16 / ALL ENCODINGS CAN BE USED. CML, RAR, RAL, RTR, RTL, AND IAC ARE
17 / ALLOWED. YOU CAN'T SPECIFY CLA, CLL, OR CMA OPERATIONS.
18 /
19 / FORTUNATELY THIS STILL LEAVES A LOT OF POSSIBILITIES BUT YOU ARE
20 / BASICALLY LIMITED TO THE BOTTOM 32 WORDS OF MEMORY AND NO INDIRECTION
21 / WHICH ALSO MEANS NO SUBROUTINES BECAUSE THE RETURN REQUIRES
22 / INDIRECTION.
23 /
24 / THE BOOT2 PROGRAM STARTS WHEN THE LOAD OVERWRITES THE FIRST INSTRUCTION
25 / OF THE BOOT1 PROGRAM. THIS WILL BE A JMP PATCH. BOOT2 WILL READ THE
26 / BOOT BLOCK INTO MEMORY STARTING AT ADDRESS 0. IT WILL READ 256 WORDS
27 / AND THEN MOVE THE TWO MEMORY RESIDENT SECTIONS INTO THEIR CORRECT
28 / PLACES. FINALLY IT WILL PERFORM A JMP TO 7605 WHICH STARTS OS/8.
29
30 / THE BOOT 2 PROGRAM:
31
32 / THE BOOT2 PROGRAM REQUIRES INDIRECTION IN 1 PLACE. THIS IS THE
33 / INDIRECT DEPOSIT THAT STORES THE RECEIVED WORD IN MEMORY. THE BIT THAT
34 / CONTROLS INDIRECTION IS THE 0400 BIT SO ALL WE HAVE TO DO IS CREATE
35 / THAT AND ADD IT TO A REGULAR DEPOSIT. THE CLL RTR;RTR WILL DO THIS
36 / NICELY SO WE DO THAT FIRST TO PATCH THE DEPOSIT.
37 /
38
39
40
41 / WHAT IS EXPECTED OF THE SERVER:
42
43 / THE BOOT1 CODE WILL BE TOGGLED IN AND STARTED. THE SERVER WILL BE TOLD
44 / TO PERFORM A BOOT WITH SHIFT F12. THE SERVER WILL SEND THE BOOT2
45 / HELPER CODE AND THEN IT WILL SEND THE BOOT BLOCK. THE EXTENDED VERSION
46 / OF BOOT2 THAT IS FOUND IN THE BOOT RECORD WILL TAKE OVER WHEN ALL 256
47 / WORDS HAVE BEEN REVEIVED.
48
49 / HERE ARE THE BOOT2 HELP CODES:
50 / ADR HLP INST ASSEMBLY
/ CONSOLE SERIAL DISK OS/8 HELP BOOT Page 2
51
52
53
54
55
56 / THE BOOT2 LOADER:
57
58 / A WORD ABOUT THE .-. CONSTRUCT.
59
60 / I SAW THIS IN SOME CODE I WAS READING A VERY LONG TIME AGO AND DECIDED
61 / TO USE IT LIKE THEY WERE. AS A PLACEHOLDER FOR SELF MODIFYING CODE OR
62 / THE RETURN ADDRESS LOCATION OF A SUBROUTINE. IT STANDS OUT FROM THE
63 / TEXT AROUND IT SO IT CATCHES YOUR EYE AND YOU KNOW SOMETHING
64 / INTERESTING IS HAPPENING HERE. THE CALCULATION IS CURRENT ADDRESS
65 / MINUS CURRENT ADDRESS WHICH IS ZERO.
66
67 / THE WORD COUNT MUST BE INITIALLY -0400 (07400) BUT THIS IS ONE OF THOSE
68 / VALUES THE HELP LOADER CANNOT GENERATE. HELP SENDS A ZERO BUT THE BOOT
69 / BLOCK WILL HAVE THE CORRECT VALUE SO IT IS ALL GOOD.
70
71 0000 *0000
72 00000 0000 BTWC, .-. /WORD COUNT TO TRANSFER (SET TO 7400 BY BOOT RECORD)
73 00001 0000 BTCA, 0 /CURRENT ADDRESS TO STORE WORD. SET TO 1 BY BOOT RECORD
74 00002 0000 BTTMP, .-. /THIS IS AN INITIAL DONT CARE VALUE.
75
76 00003 7032 PATCH, CML RTR /BUILD A 0400 INDIRECTION BIT
77 00004 7012 RTR
78 00005 1021 TAD PTCHME /AND APPLY TO THE DCA
79 00006 3021 DCA PTCHME
80
81 00007 6031 BOOT2, KSF /GET A CHARACTER FROM SERIAL DISK SERVER
82 00010 5007 JMP .-1
83 00011 6036 KRB
84 00012 7006 RTL /LEFT SHIFT 4 BITS TO BUILD UPPER HALF
85 00013 7006 RTL
86 00014 3002 DCA BTTMP /SAVE FOR COMBINE
87 00015 6031 KSF /GET LOWER 6 BITS
88 00016 5015 JMP .-1
89 00017 6036 KRB
90 00020 1002 TAD BTTMP
91 00021 3001 PTCHME, DCA BTCA /STORE THE WORD IN MEMORY (MODIFIED TO A DCA I BTCA)
92 00022 2001 ISZ BTCA /POINT AT NEXT ADDRESS
93 00023 2000 ISZ BTWC /SKIP IF DONE
94 00024 5007 JMP BOOT2 /GO DO THE NEXT WORD
95
96 / AN EXTENDED VERSION OF THE LOADER FOR THE BOOT RECORD STARTS HERE. SEE
97 / THE HANDLER FOR THE BOOT RECORD VERSION
98
99 00025 5003 JMP PATCH /THIS OVERWRITES THE KSF AT BOOT1 TAKING CONTROL
100 NOPUNCH
/ CONSOLE SERIAL DISK OS/8 HELP BOOT Page 3
101 0025 *.-1 /THE JMP BOOT2 ABOVE WILL OVERWRITE THE KSF BELOW
102 00025 6031 BOOT1, KSF /SKIP IF SERVER HAS SENT US A CHARACTER
103 00026 5025 JMP .-1 /WAIT FOR A CHARACTER
104 00027 6036 KRB /READ THE CHARACTER
105 00030 7012 RTR /MOVE BITS INTO POSITION
106 00031 7010 RAR
107 00032 3001 DCA Z 1 /STORE THE INSTRUCTION. MODIFIED BY THE FOLLOWING ISZ
108 00033 2032 ISZ .-1 /BUMP THE STORE ADDRESS
109 00034 5025 JMP BOOT1 /GO DO NEXT ONE
110 /END OF HAND TOGGLED CODE
111
112 ENPUNCH
113 $
No detected errors
No links generated
/ CONSOLE SERIAL DISK OS/8 HELP BOOT Page 4
Cross Reference
1 A 102 BOOT1 109
2 A 81 BOOT2 94
3 A 73 BTCA 91 92
4 A 74 BTTMP 86 90
5 A 72 BTWC 93
6 A 76 PATCH 99
7 A 91 PTCHME 78 79
The high here yesterday was 105F (40.5C). I think we had you beat. But we get temps like this every few years and AC is common because of that. I hid in the basement and worked on handlers. My AC was not keeping up but the basement remained tolerable. Todays high is going to be 87F (30.5C) so quite a bit better.The biggest problem at the moment is the record temperatures in the UK...
Is anyone else interested in those Omnibus USB serial I/O boards? I'm aware of two designs.It seems terribly slow at 9600 baud so I am going to switch to 19200 which is the fastest I can do on an M8655.
I receieved today prototype PCBs of my take on thiis. I've got a few AT1508 supposedly on the way, arriving end of week. I should be able to try something sometime next week.Is anyone else interested in those Omnibus USB serial I/O boards? I'm aware of two designs.
