Tdillon
Sorry, I didn't get that part about extra out images. Can you explain?
If I get a moment I will send you the waterloo files in a zip file and not in a .d64 image. You can use cbmxfer to extract files out from a .d64 image. The Waterloo programs are contained in a .d64 image. You can open the image in basic using the commands found on the sd2pet sheet.Sorry, I didn't get that part about extra out images. Can you explain?
I saw the early posts of your work and it's really great stuff!Yes, the languages are on the disk and not stored in ROM.
There are copies of the Waterloo language disk around that have the 6702 protection disabled. I know because I did it! If your 6702 chip goes faulty, you will need them...
I can point you at them if you can't find them...
My disk image also has a "Hello Dave" program for every computer language on the disk...
Assuming the protection board still works. If not will extract your .d64 images for him if needed.
Sent you a PM on a different issueMy D64 images also have "Hello Dave" tests for all of the Waterloo Languages to make sure everything is working. The documentation is also on the website for running these.
I copied the original protected WATCOM programs and files to the SD2PET, and it successfully loads. The chip is apparently working correctly.Try this - extract the zip files on the the SD2PET SD card. Type edit or basic and see what happens. If it doesn't load in lower case try upper case
That good …. have Fun playing around with it … then when you have finished maybe you want to try a OS/9 board add on needs to be built up but another world for the SuperPETI copied the original protected WATCOM programs and files to the SD2PET, and it successfully loads. The chip is apparently working correctly.
The thought has crossed my mind. I have restored 4 (PET/CBM/SP9000) in the past couple weeks but still have 3 more to go. And I'm looking at getting more as well. I've no idea why really, but I'd like to see more people somehow connecting with them. A MUD game would be fun.That good …. have Fun playing around with it … then when you have finished maybe you want to try a OS/9 board add on needs to be built up but another world for the SuperPET
