Pet Dynamic Board UD5 ROM Question
Hugo Holden
Australia
Since I suffer from a spare parts disease, I saw a dynamic PET board on ebay, just like the one in my recently acquired PET, so I thought I would buy it as a spare.
Oddly because my original PET board had no hardware faults and I did not have a fault to sort out and repair. I find if I have a faulty board, I learn a lot more about it trying to diagnose and repair a fault. Seems odd but that is the way I learn about some designs.
So I bought this similar board, in the hopes that it might actually have a fault I could get to repair. I have not tried it yet.
This one has the extra bank of memory chips installed, hand soldered, no sockets, so I assume like my original board, it has the upgrade to 32k memory.
It has all original MOS ROMs it appears:
UD9= 901465-03
UD8= 901474-01
UD7= 901465-02
UD6 = 901465-01
UD5 = 901447-29
The thing is my original PET board did not have any IC installed for UD5.
What does the UD5 ROM do ?
The answer is nothing!
The 901447-29 ROM is the "Screen editor for BASIC 4, normal keyboard, no CRTC (40 columns)" (i.e. it should live in socket UD8 not UD5 and is for a different version of BASIC).
I suspect someone has stuffed this ROM into this socket to confuse someone...
If you don't already know, you can look up 99% of the ROMs here: http://www.zimmers.net/anonftp/pub/cbm/firmware/computers/pet/index.html
It confused me ! That is interesting, thanks, I will remove that ROM. before I try out the PCB.
It is definitely not required for BASIC 2 - but BASIC 2 should still work OK with it in position.
All the big chips are socketed. That is good news and bad news. It is very helpful when troubleshooting a broken board, but those sockets can cause connection problems over time. Are you considering using some contact cleaner on those sockets? it may be a good idea if your board does not come up. Certainly you should rock the chips in the sockets to rub off the oxide.
I can't get over how good your board looks. Someone took good care of it.
I have standard protocol where before even testing the board I remove the socket IC's and clean the oxides off the pins,also I test each socket pin for tension with a test pin and I also lubricate all of the pins and sockets with Inox's mx-3 this way I don't run into bad socket connection issues.
It does seem to be a remarkably clean board.
