Dwight Elvey
I just checked the voltages pin 1 and 51 are both +8V.
Pin 2 is +18V and pin 52 is -18V are you sure you didn't mix 2 with 52?
If one of the diodes is blown open, the voltages will look normal but the ripple will be too much for most logic to work right.
I'm not sure it the +8V line is two diodes with a center tapped transformer or a 4 diode bridge.
Dwight
Dwight
