plagued
- Joined
- Jun 30, 2024
- Messages
- 112
at the moment I'm not certain I have made a boot disk.... or have any combination of things that might be bootable.
I fail at the first hurdle. I can load the SAFORMAT util via the serial port, but no matter which options I choose it errors without any indication it's trying to format anything. The disk spins and locks but no head movement it just errors. This is the same behaviour with the Gotek.
So I thought I'd try and boot from the Gotek as I can set that as an 80track DD DS drive to match most of the disk images, but I get the same behaviour that I do with the floppy drive with any disk in when trying to boot, so it behaves like there is no valid track0.
I also thought I'd test the drive independently with a greaseweazle on my PC, where I can read and write to them. I picked the MDEX boot loader single density disk image as although the bin file is 321k there's only about 80k of data on it and used the greaseweazle (set to 40 tracks single sided) to burn this image to a floppy. I then read back the disk and verified the image compared to the original and it looked the same, just less empty space at the end of the disk image. It's entirely possible that burning an 80 track image to a 40 track disk just won't work in the Cortex, even if it reads back at 40 tracks externally, but I was running out of things to try.
I don't have a CDOS cassette image to try anything with, only the SAFORMAT one in the PC coms util. I would just concentrate on that refusing to format, but it's a pain in the ass to type in the code to redirect the cassette data to the serial port each reboot
I have no idea if this cortex actually ever fully worked, as it was one of two and the previous owner had passed. Some of the build was incomplete like the front LEDs on the case, no bleeper, no fan and a couple of missed solder points, but I'm currently going on the assumption that it was all working and in use even if there were some slightly unfinished bits, as the reset and warm start were redirected to buttons mounted to the side of the keyboard, which would be an odd thing to do if you weren't fed up with reaching round the back all the time.
For reference, the current Gotec config I've been trying is:
[CORTEX]
mode = mfm
rpm = 300
rate = 250
cyls = 80
heads = 2
secs = 16
bps = 256
interleave = 1
skew = 0
id = 0
index-suppression = no
step = 10
settle = 10
motor-delay = 0
[CORTEX]
mode = mfm
rpm = 300
rate = 250
cyls = 80
heads = 2
secs = 16
bps = 256
interleave = 1
skew = 0
id = 0
step = 10
settle = 10
motor-delay = 0
