Marty
Hi All;
Thank You, Chuck !!
I am going to try and do two things.. First, because of Your Help and Suggestions and Downloads, I will put into NotePad what I think is the origional file that might be the equations file, that You, Chuck talked/asked about earlier..
And see If by making a New file from scratch, might be the trick to make it work..
The other thing is to try and see where the Code is Hanging up, in the 003.. I have been trying to Remember by using my old Spectra Test Panel and Spectra 2A Test Panel.. But, things are not coming to mind and/or not working as I had hoped..
Here are some Pictures of the Test Panel and 2A Test Panel:
Here is the Equation file :
View attachment 16L8-DES.txt
THANK YOU Marty
Thank You, Chuck !!
THANK YOU Marty
