So I'm digging through all my old stuff here and in the pile are three Sun386i's that I last used back in the 90's. One of them has a CG3, one has a CG5, and the third has a mono display card. All have been stored in the bedroom closet and haven't been powered up since about 1996 I think.
Anyway I'd like to see what's on them so I have been trying to figure them out. Of the three two have power supplies and both blew up on the bench while testing.
Anyway, things I have forgotten:
The old Sun 386i FAQ is good and I did re-read it, but I think it could use some updating....
Thanks for any thoughts.
C
- Problem 1: Anyone have a schematic for them? They seem to be the usual "rectify AC to 300v, then pass through two FETs to make AC for a transformer that then goes to a set of rectifiers to make +5 and +12. The main power FETs aren't shorted but it looks like the circuit board to gate them has problems. Not sure where, working on it but a working schematic would help.
- Problem 2: With the supplies out I did try back-feeding +12 and +5 into the CPU board with an ATX supply. All the test LEDs go on but that's it. I reconstructed the -5 and -12 supplies as well with isolated supplies but no difference. Sun4 keyboard beeps, LED for mouse is on, fans work, that's it.
- Problem 3: No display signal (I'm using a 4 BNC to VGA adapter to an LCD display). I'm not sure if that works, is anyone running a 386i on a more modern flat panel screen?
- Can the systems run without a frame buffer? It would be nice to simplify this.
- I know the power supply outputs +5, +12, -5, and -12 but there's also one last tab I don't know what it is. Is that a 60 cycle system clock? Interlock? Something else?
- Could the SCSI drives be mounted on another system? I don't remember if UFS was around on 4.01 and 4.02 but if so could I mount them on my NeXT or something like that in read only mode?
C
