jdreesen
The Datapoint 9350 is also a Diablo-30 series disk, with 24 sectors. I have the controller & drive, but no documentation beyond the command description, as found in Bitsavers.
VCF SoCal | Feb 15 - 16 2025, | Hotel Fera, Orange CA |
VCF East | Apr 04 - 06 2025, | Infoage Museum, Wall NJ |
VCF Southwest | Jun 20 - 22 2025, | University of Texas at Dallas |
VCF Southeast | Jun 20 - 22 2025, | Atlanta, GA |
VCF West | Aug 2025, | CHM, Mountain View, CA |
My SWAG is that's a standard 30 Series drive interfaced through the same controller as the 6045 Cartridge Disc Subsystem, and using the same software interface. As Al Kossow pointed out earlier, DGC got a lot of mileage out of their early hardware designs, using the same "DISK CARTRIDGE CONTROL" board for both FDD and removable HDD (and the fixed side of the HDD had to work the same ...). Unfortunately surviving DGC documentation of all forms is sparse.The photo I was referring to is two photos below that one in the Wikipedia page, "A Nova 1200, mid-right, processed the images generated by the EMI-Scanner, the world's first commercially available CT scanner.":
Data General Nova - Wikipedia
en.wikipedia.org
I'd be interested in the Data General disk controller for that configuration.
The controller in question is not the same as the controller for the 6045.My SWAG is that's a standard 30 Series drive interfaced through the same controller as the 6045 Cartridge Disc Subsystem, and using the same software interface. As Al Kossow pointed out earlier, DGC got a lot of mileage out of their early hardware designs, using the same "DISK CARTRIDGE CONTROL" board for both FDD and removable HDD (and the fixed side of the HDD had to work the same ...). Unfortunately surviving DGC documentation of all forms is sparse.
The HP7900A (http://www.hpmuseum.net/display_item.php?hw=275) is a similar era drive/interface that would be of interest to hobbyists. You can download documentation for it from the HP Museum, and also Bitsavers:
At least three.Great information @Nevets01 -- thanks for "speaking up". I wonder how many 4046 & 4047/4049 subsystems survive?
Thanks! I browsed through some of the Datapoint documents on BitSavers but wasn’t able to find specifics about the disk controller and disk format.The Datapoint 9350 is also a Diablo-30 series disk, with 24 sectors. I have the controller & drive, but no documentation beyond the command description, as found in Bitsavers.
Wow! Thanks for sharing so many details regarding the Data General controllers. It’s exactly what’s useful to me to understand where the emulator might be practical to use.The controller in question is not the same as the controller for the 6045.
It would almost certainly be a Data General 4046 and 4047 (the other possibility is a 4046 used with a 4049; the 4049 supported four diablo 31's, the 4047 supported two. Since there is only one drive present, I think it is more likely to be a 4047) the 4046 is the card that goes in the Nova chassis, and the 4047 occupies a separate rack-mount box. A cable would run from the backplane at the slot where the 4046 was installed, to the 4047, and another cable would connect the 4047 to the diablo 30-series drive.
Like so:
One (arguably dubious) benefit of such a setup, is that two novae can share a hard drive (or chain of hard drives): there were two connectors on the 4047 to connect to the Novae.
You can see the 4047 in the Wikipedia image, I've indicated it here in red:
The 4046 was unfortunately not designed to work with a floppy drive like the 6045's controller (AIUI, it could not have been, as floppy drives were not sold at the time it was designed (1971) except as a part of an IBM computer)
The 6045 was somewhat similar in concept, and had a similar (but not compatible) programming model (see pages 163 and 205 of this programming reference), but was different in construction and signalling standard. DG did decide to retain the "two novae use the same drives" capability, though in this case the other Nova connected to the other end of the drive daisy-chain. In physical construction the 6045 is much more like the Diablo 44. The 6045 controller could control a 6030 or 6031 floppy drive(s). (The 6031 has two drives where the 6030 has one)
I think the 4046 and 4047 would be more relevant here, because they speak directly to a stock Diablo 3X-series drive (possibly also Diablo 44 drives, though I have not yet confirmed this) so would likely be quite happy talking to an emulated RK05.
Thanks much, Paul. Yes, the low-level details of the sector timing are especially interesting. I need to pair up the RK05 signals with the 4047/4049 signals to confirm the similarities.Best of luck with that :-}. Key documentation for @gwiley:
Not long ago I asked a member of the cctalk list about this and sent me a few photos of the RK11-C to Diablo 31 / RK03 connector boards.If anyone has RK8E cables for the Diablo Model 30 or adapter/converter boards to go from the four row pin Diablo connector to the RK05 Edge connector, please let me know.
Thanks for asking. It's taking a bit longer than expected, plus there's been some recent travel that's slowed things down. The emulator and tester version of the same hardware seem to have most of the basic functionality working. Wrote a debug monitor that runs on the RPi Pico, runs on both emulator and tester, to peek and poke registers in the FPGA. Can transfer data between the microSD and DRAM and can perform disk read/write operations through the RK05 bus. All of the field durations are now adjustable with registers in the FPGA so we can adjust preambles, postambles, data length, number of sectors, etc. Also three recording rates (1.44M, 1.545M and 1.6M) are select options.George, how goes the project? I am certainly interested in one and will gladly be a beta tester. I've done quite a bit with Xilinx, though I've been looking at giving Lattice a try. Let me know if I can be of any assistance as a tester, please. I've got an RK8-E passing diskless diagnostics ready to go!
Sorry to hear.My development https://pdp11gy.com/RK05_Emulator_E.html
has been hibernated and will probably not be further developed.
If you need assistance to design a PCB and have a schematic then I'm willing to help.I don't plan developing a PCB board either.
Both the RK8-E controller for PDP-8 Omnibus and RK11D for PDP-11 seem to be difficult to find. However, I have seen two RK11D controllers on ebay in the past 6 months. I think listings are sometimes regional depending on where the seller is willing to ship. So I may see something that you wouldn't and vice versa.Mainly I lack access
to a PDP-11 with RK11 controller.
