CPU accelerator | product name | (Driver to use) | remarks |
..EUA, EUB, EUF, EUD .. | (.........) | A window accelerator is required to increase the resolution to 640 x 480 or higher, and the internal memory of the main unit is required to be 8MB or higher. |
Hello
Quite agree, if extra memory can operate on the Buffalo cpu-board, then more advanced OS's are possible.
And the product is of the shelf, and not some thing we have soldered together ourselves (another plus , i think).
But if you read here:
https://web.archive.org/web/20061231...5/0095cpu.html
(selective copy, from link above):
CPU accelerator...i read it as follows: It is not possible to start without 8 Mb ram on the "motherboard".
CPU accelerator product name (Driver to use) remarks ..EUA, EUB,
EUF, EUD ..(.........) A window accelerator is required to increase the resolution to 640 x 480 or higher, and the internal memory of the main unit is required to be 8MB or higher.
Or could it be read in another way ?
But again , if it is possible , it should be investigated
/cimonvg
Did buffalo memco ever have memory upgrades that fit into a 286 cpu socket?The Buffalo/Melco Hyper memory modules most likely work with the Inboard 386.
Any additional memory on these upgrades is mapped to above 16m.
A special driver (up16mem.sys) is needed to make the memory visible for dos.
Im trying to get one of these modules in japan. I have not been able to win an auction at the moment.
-Jonas
helloHi All,
I recently have gotten an Inboard/386 and I am interested in getting as much speed as possible out of it. I am not even sure what to search for to buy an interposer. I can see AM5x86's but that can't work without something to make the 386 work like a 386. I can find several 386 to 486 upgrade chips so I am interested in those. I have no issues with changing the oscillator on the board - I see that people have had success at 46 MHz. Does that imply a base clock rate of 23 MHz? Has anybody tried a 386DX 40 Mhz with an 80 MHz Oscillator? Anyway, I hope to get the 4 mb board and build it.
One other odd question is that when I run Himem.sys I cannot see XMS when I use the MEM command. I see that one of you was running 4DOS - does that work better?
Anyway, here are the things I can think to try to get a faster system with stuff I can actually buy at the moment, and curious if they have been tried and what success you have had?
Other 386's like 20/25/33/40 with corresponding oscillators
Intel RapidCAD
Cyrix Cx486DRx2 25/50 MHz
Cyrix Cx486SRx2 25/50 MHz
IBM Blue Lightning
I see that you are somehow getting the 386 port to turn into a 486 port and then using the various clock multipliers, etc. What I don't understand is how do you get to the first step of 386 to 486 with the ability to change the CPU? Is that the Interposer - the Compaq upgrades?
Lastly, I am really looking to see what I can do with the upgrade in terms of playing games that I couldn't play with my 286 card. One thing I have noticed is that in spite of the TOPBENCH score being the same, many games run much faster with the 386 16 Mhz, like Sierra Hoyle's Book of Games, or Galactix. Any real world gaming experience or fun things you have done? (Play AVI's maybe? Or MP3's?)
Thanks,
Chris
How are you running the Cyrix? What interposer do you have?hello
Watch out for the frequency, the CPU can handle alot more then the Inboard386. I do run 20Mhz (40Mhz crystal) on my inboard386 and with the x4 setting on the Cyrix5x86 it runs like 80 Mhz - and i have not seen any errors due this frequency (yet). You never know if errors will appear, now we are running out of ordinary spec. boundaries. I have not tried higher crystals then the 40Mhz in my setup, so i can not advice you with higher frequency.
I think the fastest at this moment is Stunx's Overdrive solution.
/cimonvg
helloHow are you running the Cyrix? What interposer do you have?
My kingdom for a Transcomputer Interposer....hello
i do use Transcomputer interposter (if you look 2 pages prior this page).
There is uploaded a "jumper settings" sheet on "https://forum.vcfed.org/index.php?threads/running-486-on-inboard-386.47554/page-2" , but that is another interposter board.
And a VRM, due to the CPU do not like 5volt.
/cimonvg
(I will respond to myself.) Yes, you can use a Kingston 486/33 486Now! and a Kingston Turbochip with an Inboard/386. Although you can overclock the 486Now! with a 40 MHz crystal, the system isn't stable and you get errors.Hi. Has anybody used a Kingston 486/33CD3 (486 Now!) on their inboard 386 and been successful? Particularly using a 5x86 with a voltage converter?
Ok so all I can get to work is a 41 MHz on the Inboard. I now have a 486Now! running with a Evergreen Tech 5x86 set to X4. The 486Now is overclocked to 40 MHz. The CPU itself is running at 160 MHz but of course that only gets to run at 20.5 MHz to the Inboard. Not sure how all of that works but it does work. Sadly this only gives me a 45 in Topbench. I can ALMOST play a 44.1 Khz MP3 file. It can play a 32k stereo one in real time. Game performance is really good, can't seem to get the DOOM test to work in Dosbench tools. My challenge is that the 16k of cache on the AMD 5x86 will only run in Writethrough mode and I can't seem to find a tool to enable write back. I've seen some musings about how to add a wire to force WB - anybody want to give me a hint on that one? Can't find a Buffalo Interposter, and sad that even though I have a 5x86 running I can't get close to the performance I am reading about. Any ideas?(I will respond to myself.) Yes, you can use a Kingston 486/33 486Now! and a Kingston Turbochip with an Inboard/386. Although you can overclock the 486Now! with a 40 MHz crystal, the system isn't stable and you get errors.
My performance does not seem close however to others on this thread. Certainly it is fast in comparison but Topbench scores me like a 386 33 MHz. For those getting to the 15 fps on DOOM - what Topbench scores are you seeing? It shows I have cache enabled, but I still think I need to play around with it. It also shows a clock speed of the full 133MHz but I think that is because the 486Now has its own clock. My Inboard has a 40 MHz crystal. I have 41, 42, 43 and 44 to try. My 45.5454 doesn't post.
Did you ever try these in a 386? Which Buffalo module did you use? Was it this one?I have the Buffalo Modules here now... booting is quite the chore. It takes for EVER until DOS loads!
The Japanese homebrew 16GIGA.SYS TSR does not work just adding it in the config.sys and hangs up in a loop, at least for now.
Maybe it can be modified since the sources are included (TASM3.5).
The UP16MEM.SYS from Melco will just hang and do nothing, not even an error message is given.
EDIT:
My "research" has shown the following results:
The inboard reservers 16768k + 640k + 64k of memory space. This may conflict with the Buffalo upgrade. I don't really know if that is the reason why the two drivers are not working. The upgrades itself are starting normally without the XMS driver. The speed is a bit lacking. Especially memory transfer rate takes a big hit and ranges around 14-16Mb/s with 20Mhz bus. My guess is that the modules are especially optimized for the timing of the computer they were originally intended for (PC9801FA and PC9801BA in this case).
I will try these upgrades in other 386/486 computers with limited upgradeability. Maybe i can get them working there? But that will take some time...
Do you have stock RAM in your 5150 at 150 ns? I have tried everything to get my main system RAM read speed to get closer to yours. I have a 486Now with an Evergreen AMD 5x86. I have L1 and L2 cache because of the 486 Now but it is all in write-through mode. Not sure how I would go about forcing write back on the 486Now or on the Evergreen as it is set to write-back. Anyway, I'm curious if you have done anything to get the main memory speed of 20.2 meg/sec and I am only getting 10.5. I am pretty sure this is what is holding me back. My TOPBENCH is only 46. I tried changing out oscillators on my CPU board. (I am running this is a Vendex 888-XT.) Changing the Oscillators didn't do anything productive. Oh and I have the homebrew 4 meg upgrade and it has 60 ns Parity DRAM in it but my onboard DRAM is only 150 ns. Racking my brain here to try to get better performance!
I would reduce the 8 bit ram to as small as possible 64k? And use only inboard ram for base + extended.Do you have stock RAM in your 5150 at 150 ns? I have tried everything to get my main system RAM read speed to get closer to yours. I have a 486Now with an Evergreen AMD 5x86. I have L1 and L2 cache because of the 486 Now but it is all in write-through mode. Not sure how I would go about forcing write back on the 486Now or on the Evergreen as it is set to write-back. Anyway, I'm curious if you have done anything to get the main memory speed of 20.2 meg/sec and I am only getting 10.5. I am pretty sure this is what is holding me back. My TOPBENCH is only 46. I tried changing out oscillators on my CPU board. (I am running this is a Vendex 888-XT.) Changing the Oscillators didn't do anything productive. Oh and I have the homebrew 4 meg upgrade and it has 60 ns Parity DRAM in it but my onboard DRAM is only 150 ns. Racking my brain here to try to get better performance!
I wonder if it will work that way. I have 256k soldered to the CPU board but easy enough to socket it.I would reduce the 8 bit ram to as small as possible 64k? And use only inboard ram for base + extended.
On an IBM 5150 PC you could jumper all the way down to 16k (model 1) or 64k model 2I wonder if it will work that way. I have 256k soldered to the CPU board but easy enough to socket it.
