UC07 F.R.D. and SCSI2SD dialog
I'm not yet knowledgeable enough regarding the UC07 and your setup to ask any specific questions, but I do hope to replicate your experience/configuration over the end-year holidays. So any notes that you'd care to share while it's fresh in your mind would certainly be appreciated!
Thanks,
paul
Paul,
Below is a copy of my dialog with F.R.D. I highly recommend reading the pages of the manual to understand the values that can be set. I have a long (4 ft.) unshielded cable so I chose a non-default setting for longer SCSI cables. Also, a PDP-11/83 with PMI memory (inserted above the CPU in the backplane) can allow the Qbus to be hogged by the disk controller more so I chose values of 8 for the DMA threshold and 2 for the DMA burst delay. Most everything else I took the default. Also, the UC07 thought the disks were RA81s although they are sized for RD54 size images. Eventually I do want to set the SD cards to be RA81 or bigger, but I am making changes one thing at a time.
Matlock
Using the SCSI2SD with Emulex UC07
Configuration of UC07 for two SCSI2SD cards.
Get a copy of UC0751001-F_UC07_Feb90.pdf
Details to invoke F.R.D. are on page 5-2
Testing in progress - Please wait
1 2 3 4 5 6 7 8 9
^C
Message 04 Entering Dialog mode
Commands are Help, Boot, List, Setup, Map and Test.
Type a command then press the RETURN key:
Hit Halt Button on Front, Invoke F.R.D. by entering code below
165232
@17772150/000000 1
17772152/005400 30003
@/000400 42000
@17772152/002000
@200G
Disk Firmware-Resident Diagnostic
Copyright (c) 1988 Emulex Corporation all rights reserved
UC07/8 controller, firmware revision level R
IP address = 172150
Option Menu
1 - Format 2 - Verify
3 - Format & Verify 4 - Data Reliability
5 - Format, Verify, & Data Reliability 6 - Read Only
7 - List Known Units 8 - Replace Block
9 - Write RCT 10 - Optical Read all Diag Sectors
11 - Optical Write a Diag Sector 12 - Issue Mode Select
13 - Display Novram 14 - Edit / Load Novram
Enter option number: 14
Note: let UC07 find and size the sd cards which need to be configured as to their size by scsi2sd-config before this.
also the cards should contain a good disk image at this point before letting UC07 try to figure them out)
Emulex automatic set-up of UCxx [Y or N, def=N]? Y
ALL DEVICES MUST BE POWERED UP AND READY
Hit any key to continue
SCSI ADDRESS 0 LUN 0, codesrc, RD54 , REV LEVEL = 3.4
SCSI ADDRESS 1 LUN 0, codesrc, SCSI2SD, REV LEVEL = 3.4
Unit offset if alternate controller address is selected, or
unit number to autoboot from if not alternate controller.
Enter unit offset/auto-boot unit number [0-15,def=0]:
Do you want to configure another unit [Y or N,def=N]?
Do you want to change any parameters [Y or N,def=N]? Y
Dma threshold [1-8,def=1]: 8
Dma burst delay in multiples of 2 [2-32,def=4]: 2
Host adapter scsi address [0-7,def=7]:
Enable scsi parity checking [Y or N,def=N]?
Enable ESP chip slow cable mode [Y or N,def=N]? Y
ST506 = 1 ESDI/EMBEDDED = 2 Optical = 3 Auto-size = 4
Type code [1-4,def=4]: 4
Current media ID is: RA81
Do you want to change media ID [Y or N, def = N]?
Full capacity mode [Y or N,def=Y]?
Do you want to enable transparent replacements [Y or N,def=Y]?
Do you want to ignore FCT errors [Y or N,def=N]?
Disable scsi disconnects [Y or N,def=N]?
Prevent manual spin-down of mounted media [Y or N,def=N]?
Enable synchronous data transfers [Y or N,def=N]?
Disable host adaptor polling of drive [Y or N,def=N]?
Scsi controller address [0-7,def=0]: 0
Scsi logical unit number [0-7,def=0]: 0
Do you want to configure another unit [Y or N,def=Y]?
Scsi controller address [0-7,def=1]: 1
** ALL DATA ON DRIVE CAN BE LOST **
DO YOU WANT TO LOAD THE NOVRAM [Y or N]? Y
Option Menu
Enter option number: 7
Drive Status Unit Size
0 Available 311136
1 Available 311136
Option Menu
Enter option number: 13
Dma threshold [1-8] = 8
Dma burst delay in multiples of 2 [2-32] = 2
Host adapter scsi address [0-7] = 7
Enable scsi parity checking [Y or N] = N
Enable ESP chip slow cable mode [Y or N] = Y
Enter unit offset/auto-boot unit number [0-15] = 0
Type code [1-4] = 4
Full capacity mode [Y or N] = Y
Do you want to enable transparent replacements [Y or N] = Y
Do you want to ignore FCT errors [Y or N] = N
Disable scsi disconnects [Y or N] = N
Prevent manual spin-down of mounted media [Y or N] = N
Enable synchronous data transfers [Y or N] = N
Disable host adaptor polling of drive [Y or N] = N
Scsi controller address [0-7] = 0
Scsi logical unit number [0-7] = 0
Type code [1-4] = 4
Scsi controller address [0-7] = 1
Option Menu
000402
1 2 3 4 5 6 7 8 9
Starting system
RSX-11M-PLUS V4.6 BL87 2044.KW System:"RSXMPL"
>RED DU:=SY:
>RED DU:=LB:
>RED DU:=SP:
>MOU DU0:"RSX11MPBL87"
>@DU:[1,2]STARTUP
>; PLEASE NOTE
>; If you have not yet read the system release notes, please do so
>; now before attempting to perform a SYSGEN or to utilize the new
>; features of this system.
>* Please enter time and date (HH:MM DD-MMM-YYYY)
: 9:41 27-JUL-2014
>TIME 9:41 27-JUL-2014
>ACS SY:/BLKS=1024.
>CON ONLINE ALL
>ELI /LOG/LIM
>CLI /INIT=DCL/CTRLC/DPR="<15><12>/$ /"
>INS LB:[1,1]RMSRESAB.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]RMSLBL.TSK/RON=YES/PAR=GEN
>INS LB:[1,1]RMSLBM.TSK/RON=YES/PAR=GEN
>INS $QMGCLI
>INS $QMGCLI/TASK=...PRI
>INS $QMGCLI/TASK=...SUB
>QUE /START:QMG
>INS $QMGPRT/TASK=PRT.../SLV=NO
>QUE LP0:/CR/NM
>START/ACCOUNTING
>CON ESTAT LP0:
>QUE BAP0:/BATCH
>QUE BAP0:/AS:BATCH
>@ <EOF>
>sho dev
VF0: Offline Loaded Type=unknown
VF1: Offline Loaded Type=unknown
CO0: TT0: Loaded
TT0: [200,200] [200,200] - Logged in Loaded
TT1: Offline Loaded
VT0: Loaded
VT1: Loaded
RD0: Loaded
DL0: Offline Loaded Type=unknown
Seek_Optimization=Nearest:0.
DL1: Offline Loaded Type=unknown
DU0: Public Mounted Loaded Label=RSX11MPBL87 Type=RA81
DU1: Loaded Type=RA81
DU2: Offline Loaded Type=unknown
DU3: Offline Loaded Type=unknown
MU0: Offline Loaded Type=unknown
NL0: Loaded
TI0:
CL0: TT0:
SP0: DU0:
LB0: DU0:
SY0: DU0:
>mou du1:/ovr/pub/vi
Volume Information
Class: Files-11
Device: DU01
Volume label:RSX11MPBL87
Pack serial: 00000001236
Owner: [1,1]
Protection: [RWCD,RWCD,RWCD,RWCD]
Default: [RWED,RWED,RWED,R]
Processor: F11ACP
>pip du:/fr
DU0: has 167997. blocks free, 143203. blocks used out of 311200.
Largest contiguous space = 147509. blocks
12122. file headers are free, 2878. headers used out of 15000.
>pip du1:/fr
DU1: has 168007. blocks free, 143193. blocks used out of 311200.
12123. file headers are free, 2877. headers used out of 15000.
