gslick
Well, that didn't work. I made the partition just under 2GB. I also did a chsum of
the original Simh file and the transferred to my Linux box. Matches so it copied
Ok and matches in size. Guess RSTS doesn't want to be run on my 11/84.
I could try overwriting my one 2GB SCSI drive, but I don't want to lose my
BSD disk. I have no other 50 pin SCSI drives that are small.
If you have other scratch SCSI drives you can use and the only issue is that they are too large in capacity, you can use sg3_utils ( http://sg.danny.cz/sg/sg3_utils.html ) to soft resize the drive capacity down to smaller limits. I have used that several times with some 9GB SCSI drives to use them with 2.11BSD and RSTS/E 10.1 with a CMD CQD-220/TM on my 11/73 systems.
Example:
sg_format --resize --count=2097152 pd1
I believe all this effectively does is change the value that is returned in a READ CAPACITY command. It doesn't actually reformat the drive.
-Glen
