Model Limitations
5 No IAC rotate, no CMA rotate, no EAE, 4K maximum, slower
PC at 0000, Interrupts at 0001, no DMA (data break)
8/S No IAC rotate, no CMA rotate, no EAE, 8K maximum, 15x slower
(straight) 8 No IAC rotate, IOT 6004 is special, no SWP, no SCL
Nonexistent memory reference is special
LINC-8 Like straight-8, but with LINC & LINC peripherals, 4K
8/L group 3 CLA is NOP, no EAE, 8K maximum, protect switch
CDF/CIF to non-existant field is a NOP
RAL RAR and RTL RTR, perform both AND results
8/I RAL RAR and RTL RTR, perform both AND results
PDP-12 Same as 8/I, but with LINC & LINC peripherals
IOT 6006 is special, DTLA conflicts with PUSHJ
8/E/F/M CAF, BSW, Omnibus I/O, MQL, MQA, SWP
Odd semantics for RAL RAR, RTL RTR
EAE option has mode B
8/A CAF, BSW, Omnibus I/O, PUSH/POP, 128K support
Yet different semantics for RAL RAR, no EAE
non-standard LPT
VT78 CAF, BSW, Omnibus I/O, PUSH/POP
RAL RAR and RTL RTR are NOPs
Autoindex suppressed for current page accesses
No restart from HLT, No DMA (data break)
DECmates CAF, BSW, R3L, Omnibus I/O, PUSH/POP
RAL RAR is R3L, RTL RTR is NOP
No EAE, EAE operations hang
Incompatible second serial port (also model dependent)
KSF, TSF, PSF implementation botched
No restart from HLT in DECmate I
Color graphics options
Optional Z80 and 8086 coprocessor
Most of these differences have to do with the treatment of IOT and OPR
instructions. There is a difference in the treatment of non-existant
memory, and of current page indirection where the current page is page
zero. Quirks that are not fully implemented will be marked in the code
with BUGBUG: or TODO: comments, based on the percieved serverity of the
limitation imposed by their absence.
