IBMMuseum
- Joined
- Aug 28, 2006
- Messages
- 1,488
I've got my PCMIG system mostly going, but just when expecting to replace a CR-2032 (it does have an 850MHz PIII, but running NTWS), I find a "TL-5186":
The description says two pins are used, but it is four pins on the opposite side of the SBC circuit board. A good suspicion would be for a replacement external battery (I'll meter it to make sure), but I'm really shy about just tugging away right now (otherwise I just have to go through a little CMOS setup).
Does anyone have more experience with these batteries?
The system is a nice little unit. I only got to look through the vents at the PCMIG SBC before the purchase, and thought it was a Socket 7 (like my 7587/7588 IBM Industrials that are PCMIG). Not too troubling, I also have a spare Slot 1 PCMIG board that is able to do 133MHz FSB.
But this SBC will probably stay in place: It's got SCSI and dual 100BT Ethernet. With NT I won't be able to use the rear USB ports, but maybe I'll make it dual-boot to W2K Pro. The backplane has two PCI, and ten ISA slots, all unpopulated, even all the slot covers are factory-placed (I removed one that doesn't block a slot, to add the missing additional cables for an LPT and second COM port).
The Award BIOS can be set (which has an automatic baud rate as default) to throw POST codes out of the serial port, so still like its industrial appearance. It's more like a cube however, and not wide enough (14") to be rack-mounted. The vents I used to look inside would also let too much dust in for a factory use.
For interior home use, it's too noisy, at the same pitch as my RAQ550 (put together, they might resonate to break lightbulbs)...
I did find this, showing the two pins: http://www.batterycentralmall.com/Batteries/Tadiran/pdf/TL-5186.pdf
I just didn't know if the plastic base was a separate holder like a coin cell would have...
